Question about Air Innovations Ultrasonic Digital Humidifer with Digital Display - -
I had my humidifier for almost 1 year. I did not use it over the Spring and Summer months. I started using it again about 2 weeks ago. I set it up with water turned it on and but morning it had leaked into the motor area and looked like it had shorted out.....what do I do???? I sent the warranty in when I got it last year.
    Problem Solver:
  • 11 Answers
Call the manufacturer with your information. They will more than likely need proof of purchase (your old receipt) and you will have to pay shipping if the warranty is still valid.
Posted on Dec 15, 2014
ITS BEEN SITTING ON SHELF UNTIL NOW HAD IT 2 YRS PERR Dr. THIS WOULD HELP WITH BREATHING I have breathing problems=Please help me
No way of knowing, it might but it would depend on what kind of "breathing problem" you have. Try following the users manual in setting the unit up. If you can't find your user's manual, you can download one from here (The start up instructions are on the second page.)
http://www.appliancefactoryparts.com/content/pdfs/183477-1.pdf
If your using hard tap water, make certain you clean the unit every week with vinegar and water. If your using "soft" water, once a month will usually suffice.
I would also suggest using a 1/2 cap full of a bacteriacide (actual amount on bottle, usually 1 cap full per gallon), which is marketed for this specific application. A single bottle should last for years.
Jan 03, 2016 | Sunbeam Humidifiers
My 2 year old humidifier is smoking and sparking at the fan unit. This humidifier has probably only been used a total of 5 months since purchased. I am attempting to contact Crane but have a feeling I...
You definitely have a problem. One that could be costly, if you continue to use it. Whether it is still under warranty of not, you need to contact their Technical Service Dept, as they will be able to help you diagnose and repair the problem if possible.
Feb 02, 2011 | Crane Heating and Air Conditioning...
It is running but the house is only at 20% after a full week. Why can I not get it to 35% of so? I see water running when the furnace is running, So, I know it is working. My house is only 1600 sqft and it...
a couple of things, is this new or old..
1. you should have hooked up to hot water side of water not cold
2. you should have summer/winter bypass installed
3. what is your outside humidly running.
Pleas rate this response with thumps up section thanks..
Dec 19, 2010 | Honeywell HE220A1019 Whole House...
V745a water valve does not work (will not allow water through), only have unit 2 months
the value would have been stuck inside the white cap, so when you press the stick with the spring, the head of the valve should stick out. If this does not work, just remove the spring and the black stick from the value, water should come out
Dec 09, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Emitting a powder residue
its minerals in your water. not harmful at all.
Aug 07, 2017 | Vicks V4500 1 Gallon Humidifier
The spring fell out of the cap and now water leaks out. Can you get a replacement tank cap?
go to kaz.com and search using your model # (found on the bottom of the unit usually). i had to do this a few months ago.
Oct 18, 2009 | Vicks V3100 1.2 Gallon Humidifier
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Mar 17, 2009 | Sunbeam 701 Humidifier
Continuous water draining from my General 1042 Humidifier.....
This type of humidifer is known as a flow through humidifer, when running water flows through it instead of sitting in a pan. The water draining is normal. This type of humidifer will use more water than a pan type but is much healthier due to the fact that you do not get all the build up of the pan type if you ever cleaned one. also change the water panel every year. to change the water panel there will be 2 screws on the bottom pan. Remove them and the panel will come out, buy a replacement at home depot or such store if available, otherwise from a htg company. Replacement is a little tricky to get it to line up so be patient. If you cant remove the bottom panel due to lack of room, it will come out through the top. You will have to loosen and swing the water feed tube out of the way. That is the only maintainace to this humdifier. Also with this humidifier all you have to do is turn the humidistat to off in the summer, you do not have to turn off the water as with float types. Steve
Nov 28, 2008 | General Filters 1042-LH Humidifier
Air Innovations Ultrasonic Digital Humidifer with Digital Display - - Logo
205 people viewed this question
Top Air Innovations Humidifiers Experts
Paul Carew
Dennis
Are you an Air Innovations Humidifier Expert? Answer questions, earn points and help others
