Question about Hygiene for Health Hometech HI-4001 Series Feel Fresh Bidet with Warm Air Dryer
Find a wiring schematic for a feel fresh bidet series 4000
None
Lark 4000 XL manual
Download schematic wiring diagram lark 4000 xl - Google ...
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for schematic wiring diagram lark 4000 xl? Download schematic wiring diagramlark 4000 xl. schematic wiring diagram lark 4000 xl. User Manuals ...
Sep 26, 2015 | GPS
Dremel 4000 Wire Question
Look for a small notch behind the brass fitting that the brushes slide into.89fe048f-be52-4363-a092-c429f109d42a.jpg
Aug 30, 2012 | Dremel 4000 Series Variable Speed Rotary...
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Where can I get a trip screw for a paragon 4000 series timer
Open following link for Paragon timers.
4000 series uses X2772 trippers.
Web search for X2772 and some places sell them, and some sites are asking a lot of money.
You can replace paragon 4000 with 120Volt T101 Intermatic timer at Amazon for $45
Upvote the help.
May 16, 2011 | Hardware & Accessories
How to locate the Cmos battery
The CMOS battery is the RTC battery. Real Time Clock.
It's smaller version of the CR2032 batteries you're used to seeing in a desktop computer.
It's in a plastic holder that resembles a bag. The plastic 'bag' wraps around the battery.
There are two wires attached to the battery, and come out of the 'bag'.
One wire connects to the Positive pole of the battery, and the other wire connects to the Negative pole.
The wires are soldered to the Battery.
At the end of the wires opposite of the Battery is a small white connector. It's a Male connector.
The Male connector plugs into a Female connector on the motherboard.
Once you have the RTC battery pack removed, and the battery itself removed out of the 'bag', you can match up a new battery to it. Carefully make a **** in the side of the bag, and remove the battery/wire combo.
Have a competent repair person remove the wires, and connector to the old battery, and solder the wires/connector to the new battery.
Install the battery/wires/connector combo back in the 'bag', use glue to seal the 'bag' once more.
(Or you can use silicone)
The RTC Battery is on the BOTTOM of the motherboard. This means the laptop has to be completely disassembled in order to access the RTC Battery.
In the above heading it states Acer TravelMate 4000 PC Notebook. This is the TravelMate 4000 series.
There are many models in that 4000 series.
The Model Number is on the bottom of the laptop.
Models in the 4000 series are; 4000, 4010, 4020, 4050, 4060, 4070, 4080, 4100, 4150, 4200, 4210, 4220, 4230, 4260, 4280, 4320, 4330, 4330G, 4400, 4500, 4520, 4530, 4600, 4650, 4670, 4720, 4730, and 4730G.
The above Model list may not be complete.
The disassembly guide for the Acer TravelMate 4000 series will cover all of the above models.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Scroll down with your eyes to the Travelmate heading.
Go down to the third line that starts with 2700, read across to 4000.
Click on 4000.
This is a PDF file. The computer you are on now has Adobe Reader on it, which uses PDF files.
However if you do not have the latest Adobe Reader, I would suggest downloading it.
(Adobe Reader 9.3.4)
After you click on 4000 nothing will happen for up to 30 seconds. (Maybe more)
The screen will be blank. The file is downloading in the background, and after it has fully downloaded, the first page will pop up.
For additional questions please post in a Comment.
Would appreciate it if you would rate my solution.
Regards,
joecoolvette
Oct 21, 2010 | Acer TravelMate 4000 Notebook
Pegasus schematics
there is another plumbing place called furgouson i think thats how you spell it,check my spelling,lol good luck.if they don't have it they most times can order it for you.
Jul 03, 2009 | Union Pegasus F1228100PBV Series 5000...
Hygiene for Health Hometech HI-4001 Series Feel Fresh Bidet with Warm Air Dryer Logo
47 people viewed this question
Top Hygiene for Health Dryers Experts
Are you a Hygiene for Health Dryer Expert? Answer questions, earn points and help others
