Question about Staples Tools & Hardware - Others
Where can i buy staples for workzone stapler 8x11.3x1.2mm
Surfing on net Tried recommended 'Staples.com', which was no help Workzone stapler (item 90677 www.TUV.com) works well, is Austrian, bought it in Aldi, but cannot get spare staples. Thanks
Where can I get 8x11.3x2mm staples for an Aldi Workzone Staple Gun
8mm = .315" rounded to 5/16"
11mm = .445" rounded to 7/16"
2mm = .079" rounded to 5/64"
5/16 x 7/16 x 5/64 staples...
Jun 01, 2017 | Staples Tools & Hardware - Others
When on the stapling process even when it's pushed down the staple wire is not cut.
Probably too late but, here is what you need to repair this expensive stappler instead of buying a new one:
https://www.stapleheadquarters.com/ItemForm.aspx?Item=DUAX29
May 16, 2016 | Rapid DUAX Heavy Duty Stapler 2-170 Sheet...
Bought workzone hand stapler kit but have used all of the flat channel type staples can you help
sorry we do not sell anything here . go to the store you bought it from and ask any clerk .
Oct 28, 2015 | Staples Tools & Hardware - Others
Need instructions for Workzone staple gun
insert staples , point away from living things (dogs,cats,humans etc.) and squeeze the lever to discharge staples.
Mar 24, 2013 | Tools & Hardware - Others
Stockists for workzone staples
where can i locate staples for workzone sttapler
size are 8x11.3x1,2
Jan 01, 2012 | Radio Communications
Electric stapler won't staple???
hi there. i hope i can help you? what you need to do is open the stapler up check for any stuck staples? where they come out. dont put two many in at any one time. please make sure you are putting the correct staples in? is there a sound when in normal use? if yes it may well be a blockage. also check the fuse in the plug just in case ? i hope this will help you,
May 01, 2009 | Kitchen Appliances - Others
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Tools & Hardware - Others Logo
556 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Joe Ball
Joe Ball
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
