Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Water runs constantly from the R0 filter of my Honeywell HE440A humidifier into the floor drain. Why? There is also an overflow drain in the humidifier tank that goes to the floor drain as well.
There are two water lines running from the bottom of the R0 filter. One to supply water to the humidifier and a second drains water constantly into the floor. What is this second line, should it be wasting water constantly? If not, how can I fix it?
  • 2 more comments
  • Roy Roberts
    Roy Roberts Jan 02, 2015
    This is not water draining from the humidiier tank with a stuck float. This water tht does not even get to the humifier tank. Instead the R0 filter has two outlets, 1 to fill the humfier tank with the float and a second iine that is causing the problem.
  • Roy Roberts
    The problem line is NOT the one going to the humifier. So, a stuck float is not the problem. This is a second line from the R0 filter that drains constantly and does not go to the humifier.
  • Roy Roberts
    I think I finally got it.
  • Roy Roberts
    The copper line from the R0 filter goes to the humidifier tank. The plastic lince from the R0 filter drains constantly and appears to have no purpose. How do I stop it from wasting water?
  • 279 Answers
SOURCE: HE440A Steam Power Humidifier
The most common cause of overflow is when hard water deposits build up and prevent the float from closing. You'll have to open up the unit, make sure there's no water in it, and clean out any mineral deposits.
The problem with these steam producing units is that there is no built in way to remove those deposits automatically. The water comes in, evaporates, and leaves anything else that was suspended in it behind.
Posted on Nov 14, 2007
SOURCE: Honeywell HE440A steam power humidifier
Honeywell has had lots of problems with this humidifier. They are coming out with a completely redesigned steam humidifier that will be available in a month or two. If you know who installed it (through equipment stickers and such) you can probably get them to swap your old trouble prone unit for the new design for just the labor. If they won't, then push them to talk with their Honeywell distributor about it.
The problem is most likely a stuck float in the humidifier. There are two floats that run up and down. One that tells it when to add water, and one that is a safety. They both tend to get stuck with mineral deposits.
You can fix it by unplugging the humidifier, turning off the water, draining the pan (unscrew the drain on the bottom a few turns), disconnecting the water lines and wires (2 molded plugs and 2 screw terminals-don't worry about if they get swapped). There should be a couple of screws that lock it into the ductwork such that when you remove the screws you can pull the whole unit out to see inside the water tank. Then just clean everything out well and put it back together in the same order.
You really do want Honeywell to get you a new humidifier though.
Posted on Nov 17, 2007
  • 9 Answers
SOURCE: Honeywell HE220A water not reaching humidifier
Replace the Valve on the unit. Check the small filter inside of it where the waterline attaches first. If its clear and you have lots of flow from the 1/4" line the replace the valve.
Posted on Jan 19, 2009
HVACjake
  • 22 Answers
SOURCE: Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Posted on Jan 21, 2010
SOURCE: water constantly running in honeywell humidifier
I has the same problem with my HE360 unit. The unit was in fact miswired. The head unit red wires were connected directly to the blue solenoid wires, and activated the solenoid without any signal from the humidistat. As soon as the unit is plugged inn, the water starts running without any signal to the unit. If your unit is miswired, the soleniod blue wires need to be cut and connected to the red crimp connectors.
Posted on Oct 18, 2011
Hi, We have a new house fitted with a Honeywell HE225 humidifier. It does not seem to work. Doesn't matter what we set it to, there is still way too much condensation on all the windows. We ended up...
Cut the power to the whole house humidifier and turn off the water pipe to it. If you want it running in the winter, put the water back on, but put a timer or a humidistat on the power cable to only allow it to run a certain amount of time per day, or to only run it the humidistat shows an RH lower than 45 percent (or whatever your comfort level is).
May 27, 2017 | Honeywell HE225B Humidifier
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Two furnaces one humidistat help on wiring
Honeywell tech support is awesome here in Minneapolis, I think you need seperate humidistats but check with HW, number is in owners manual.
Nov 21, 2009 | Honeywell Power Humidifier: Furnace...
Water runs out of humidifier drain line constantly(rushes out)
Most modern humidifiers use a constant drain to flush mineral deposits, and to keep the water fresh at all times. This keeps the unit from holding standing water. This keep the water fresh and prevents mold spores from infesting the air in your home.
HVAC Teacher
Jan 27, 2009 | General Filters 1099-LH Humidifier
Honeywell HCM-305T Spits droplets rather than creating a mist.
Thanks for your question,
Sounds to me like you have something partially cloging the misting nozzle, if you can take the nozzle off, and check it I would bet there is something that got in there, if you cant, it might be better to just return the Humidifier where purchased for an exchange, if you can get the nozzle off, if you have a can of compressed air like they sell for dusting off computers, I would use a very short burst of that in the nozzle, and in the feed line, thanks again for your question, let me know how it works out,
mr.grzz
Jan 14, 2009 | Honeywell HCM-300T Humidifier
HCM 640bw leaks
Look for a microscopic crack in the water chamber. Leaking air will allow the water to continue to drain out of the tank. A bit of glue and duct tape over the crack should fix it.
Dec 11, 2008 | Honeywell QuietCare HCM-630 Humidifier
Nov 14, 2007 | Honeywell HE440A1005 Humidifier
Humidifiers Logo
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
