Question about Leica LRF 800 Laser Rangefinder
I dropped my rangefinder out of a tree. It will not work at all. There are no lines or numbers. Is it fixable or is it ready for the dumpster?
How much range should my rangefinder have?
The answer depends on the purpose of your rangefinder and your own requirements. For bow hunting, 100 yards is more than enough. On the other hand, for rifle-hunting you, the range will vary widely depending on where, what and how you hunt and on your proficiency and style. Typically you are looking at a wide range of 200 yards to 800 yards. For golfing again, it depends on the circumstances. You can work with a rangefinder with a range of anywhere between 200 yards to 600 yards. The yardage described here is relative to dark trees. Do not forget to find out what the advertised yardage is relative to - specifications can vary from highly reflective surfaces to deer sized targets.
May 27, 2018 | Optics
Tip
Eagle Dumpster Rental
At Eagle Dumpster Rental professionals in waste management are ready to help with any and all trash hauling, garbage collection and trash container needs. Eagle Dumpster Rental services the entire greater Philadelphia area with prompt and courteous service, including same day deliveries, to meet the demands of all customers. Waste containers for home clean-up projects, construction dumpsters, roll-off containers and junk removal services are all areas of expertise found from Philadelphia's top waste management and garbage collection provider, Eagle Dumpster Rental. Eagle Dumpster Rental In Philadelphia PA Wilmington DE Nearby Areas
on Oct 05, 2016 | Home
The answer depends on the purpose of your rangefinder and your own requirements. For bow hunting, 100 yards is more than enough. On the other hand, for rifle-hunting you, the range will vary widely depending on where what and how you hunt and on your proficiency and style. Typically you are looking at a wide range of 200 yards to 800 yards. For golfing again, it depends on the circumstances. You can work with a rangefinder with a range of anywhere between 200 yards to 600 yards. The yardage described here is relative to dark trees. Do not forget to find out what the advertised yardage is relative to - specifications can vary from highly reflective surfaces to deer sized targets.
Mar 21, 2018 | Optics
Which is the best laser rangefinder for long range shooting?
Sig Kilo 2000 Rangefinder
Sig is famous for its high-quality product, and Sig Sauer 2000 Kilos Rangefinder is no different. This rangefinder is being picked by most of the hunters and shooters for its 1000+ yard range which enables you to have the best hunting experience. But that is not all. The sig kilo 2000 rangefinder review describes more about it.
The Sig Sauer Rangefinder consists of a Cordoba protective carrying case, a lanyard, battery, a manual for guidance and a box for protection. The size of the rangefinder is possibly same as the size of your palm which is very convenient to use. The specifications of this rangefinder are as follows:
Specifications
  • Magnification Range: 7x
  • Finish: Matte black w/Rubber
  • Objective: 25mm
  • Eye Relief: 0.59" (15mm)
  • FOV: 34.6' @100 yards
  • Max Range: 3400 yards on Reflective targets
  • 1500 yards on trees
  • 1200 yards on deers
  • Reticle: Circle with data
  • Battery: CR2
Mar 08, 2018 | The Optics
Rangefinder is 4+ seasons old - will not lock-in
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Mar 11, 2010 | Bushnell Pinseeker 1500 Rangefinder
Use of bosch dlr165 when there is no direct line of vision
northerntool.com has a few wheel meters that roll along the ground and will give you a fairly close measurement. or you can use the string method where you take a string and stretch it as close to a straight line as possible then mark it then get it out to where you can measure the string.
Dec 24, 2009 | Bosch DLR165K Laser Rangefinder Kit
Wont turn on just replaced the battery nothing happened tryed the battery in backup rangefinder full charge what the heck?Is this fixable at home?
with what you have described this sounds as if it will need to be sent in for repari. to contact bushnell they can be reached at 800-423-3537. option 1.
Oct 05, 2009 | Nikon Laser 800 Rangefinder
Pinseeker 1500 has trouble picking up flags over 100 yards away
The unit needs an alignment. Vibration and dropping the unit is the number one killer of rangefinders.....After a while of using them, (bouncing around in golf carts, cup holders, dropping them on the cart path, or the ground) small prisms start to move inside and decrease the units effective range.... (only able to hit a target at about 150 yards or less) People that use these type of instruments have to realize that the laser beam is the straightest line in the history of man!!!. Alignment is crucial!!!
Alignment is due. For all you players that think its okay to take off the eyepiece cap.....(bad idea) This is why you see oily looking spots or black spots in the view. Direct sunlight will be magnified and burn the surface of the LCD. Bushnell is good about warranties but, if you take it apart...the warranty is void!!!! So if its 2 years old or less.....(send a copy of the proof of purchase) .send it to them. If you have sunlight burns already...this won't effect the performance of the unit. Wait till something else is wrong.
mr tech geek Rate me if you can...or find out this is the truth!!!!
Bushnell Repair Technician
Service address:
Bushnell Repair Centre
8500 Marshall Drive
Lenexa, KS 66214
send $10 for return shipping
send your problem statement and phone number.
Their number is 800.423.3537
Jul 16, 2009 | Bushnell PinSeeker 1500 20-5103...
Range finder does not register distance 99.9% of the time
I had the same problem, rangefinder would work only sometimes and only at short distances. Called customer support and was ready to send it in. Tech guy told me to turn off "First Target" ( or "last target") and turn on"LOS" (line of sight). Range finder now works perfectly at all distances. Apparently the first target feature doesnt work properly.
Dec 26, 2006 | Leupold RX-II Rangefinder
Leica LRF 800 Laser Rangefinder Logo
Top Leica Optics Experts
woodzowl307
Tom Chichester
Bill Boyd
Are you a Leica Optic Expert? Answer questions, earn points and help others
