Question about Kenmore Sears Electric Range Stove Oven 288970 Wb25m3 Indicator Light
What does the code PF 5A6 mean on a Kenmore range, model # 665.75132300?
Unplugging for 10 minutes.
buffalonyman
  • 1865 Answers
SOURCE: gas range shut off with PF on screen what does
The PF means there was a power failure, you should be able to clear this code by pressing the cancel button
Posted on Jun 04, 2009
SOURCE: Kenmore electric Range 2005
we are baking at 350 and we just received an F30 error and the oven shut off. can you tell me what this means
Posted on Nov 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore range oven model 880, broil element stays on
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
blueextc3221
  • 15935 Answers
SOURCE: What does the errror code F90 mean?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Posted on Sep 25, 2010
How can I determine the cause of the error code on my Kenmore Free Standing Electric range, Model # 911.9344190? Error code is PF.
PF stands for power failure. Check the voltage at the wall outlet and make sure the connections are tight at the terminal block...
Dec 31, 2016 | Kenmore Kitchen Ranges
What does the code PF 5Ab mean for a Kenmore range, model # 665.75132300?
It sounds like the oven control board may be faulty. Go to this site and submit your stove model for further information on this problem.
Dec 15, 2014 | Televison & Video
What when pf error come on
Hello & Welcome to FixYa
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Whirlpool Gold GW399LXU Gas Range
10 year old sears kenmore elite dryer, PF light will not stop flashing even after holding start for 10 seconds or after holding stop button for 10 seconds
Kevin
May 12, 2011 | Dryers
Sears dryer model 417.84092500. It turns on for about one second, stops, then it shows error message PF. How do i fix it?
Kevin
Mar 05, 2011 | Kenmore Dryers
Code came up when trying to set tim code " 5A6 "
The error your range is displaying is actually "SAB", which means it has inadvertently been set on "Sabbath Mode". This mode enables certain religious faiths to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
If the model number is correct, somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off. According to page 17 of the Owner's Manual, to cancel the Sabbath Mode, you need to press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Sep 07, 2010 | Magic Chef CER1115AA Electric Kitchen...
Gas range shut off with PF on screen what does
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Power Failure results in no oven or digital display.
The low voltage has ruined the CCU (clock) YOu will need to replace it. You can order the part via model # on sears.com
Nov 02, 2008 | Kenmore 92002 / 92004 Kitchen Range
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Sep 28, 2007 | Maytag MER5775Q Electric Kitchen Range
Kenmore Sears Electric Range Stove Oven 288970 Wb25m3 Indicator Light Logo
152 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
