Question about Sylvania 1997-1999 Mercedes Benz S420 Headlight Bulb, 97-99 HID-D2R
I replace new battery after that car cannot start my friend say it need to reset security system , How to do ?
Just try to start
    Top Expert:
  • Sylvania Master
  • 52,097 Answers
Call the customer service local to you security reset is a dealer only function
Posted on Feb 23, 2015
What could keep my coil from firing ? I have the Ignition control signal and 12v. while cranking over engine at the top primary wiring of coil. Can you help me get spark?
Sounds like the security system is causing your problem. Is the "security" light flashing? If it is, turn the key on, leave the key in the ON position for 10 minutes. The light will stop flashing. Now, turn OFF the key, turn it back to ON, and then crank it. It should start. If the security light starts flashing again, go through the process again until it starts. This is resetting the security system after the battery has died, battery has been changed, radio was changed, instrument cluster was removed and replaced, etc. Hope this works for you.
Mar 29, 2016 | 2001 Chevrolet Silverado 1500
When i changed ignition on 2001 ford explorer I ended up having to replace steering column now it wont turn over & the anti theft light flashes & wont stop. what can be done to get car started?
At least you know the anti theft system is working. Jokes aside, I would think that the electronic security system is not recognising the new lock and steering column. You could try leaving the battery completely disconnected for at least 2 or 3 hours to see if the system resets. Reconnect the battery and then try again with the new key. You will have to put the security code back into your radio as well. If this doesn't work, it may need to go to a Dealer to reprogram your electronic system.
Apr 13, 2015 | 2001 Ford Explorer Sport
How can I get the security light to turn off
To bypass the factory security would be difficult or car thieves would have a field day!
your best bet would be to get a replacement alarm key fob and disarm the vehicle that way!
Oct 18, 2014 | 1994 Toyota Land Cruiser
Security System Failure After battery and fuel pump replaced
Reset the system, turn the key on then off then on and let it set for 10 minutes with the key on repeat and after 3 tries you will need the dealer to reset it or find out what is wrong. In the future whenever a battery is replaced alwayas have a back voltage source avail to keep the computers memories alive.
Feb 20, 2014 | Hummer H3 Cars & Trucks
I try to start the car, and all lights on dashboard light, but the car won't start. I had a new battery installed.Recently when driving the car, a yellow security light came on. - My friend tried bypassing...
Exact same problem I had and this is was the only thing that worked: http://newrockies.ca/vatsbypass I tried the typical resistor tricks but that did not work and just wasted my time. This one will get rid of the entire security system.
Jan 25, 2010 | 1992 Oldsmobile 88
Have a issue that indicted a low battery replaced the battery have 7.1vdc at the main board when checking system status still saying low battery,
disconnect battery put dc meter on wires. should read over 6v if not need new panel. if over 6v put system in sensor test wait 5min then close cover hit status 2 times. if reset great. if not try another battery. repeat sensor test. if resets great if not need new panel. : (
Nov 30, 2009 | GE Security Simon 3 Wireless Home Security...
The battery died, now the car will not start
put in a new battery and try to start it. if the alarm is going reset it with the fob. if it is a viper alarm you need to call them to get the procedure to reset it ti so you can start it.
Nov 30, 2009 | 1997 Honda Accord
1999 Oldsmobile Intrigue security light on/power only sometimes
first thing you need to do is unhook any wiring installation you did. It sounds as if you have running your power straight to ground. Somewhere you made a wrong connection.
You have also discharged your battery as part of connecting your power lead to ground.
Disconnect what wires you hooked up for the light system and then recharge the battery. Bill
Nov 23, 2008 | 1999 Oldsmobile Intrigue
2000 porsche boxster won't start.
yes removing the battery sets off the security system and locks out the engine from starting, reset it.
Nov 01, 2008 | 1999 Porsche Boxster
Sylvania 1997-1999 Mercedes Benz S420 Headlight Bulb, 97-99 HID-D2R Logo
169 people viewed this question
Top Sylvania Optics Experts
jdtech
Andrew Taylor
Andrew Taylor
Are you a Sylvania Optic Expert? Answer questions, earn points and help others
