Question about Sewing Machines
My bobbin is making a large loop when i am using the regular stitch
I tried to change the tension, that's all
  • Sewing Machines Master
  • 1,860 Answers
Make sure the bobbin is wound correctly and inserted correctly--counter clockwise
change the needle--make sure it the right needle for the fabric being sewed
try adjusting the top thread tension
Posted on Dec 16, 2014
My PC210PRW is making large loops in the bobbin area when I speed up the stitching speed beyond the middle range. It did not do this when I first bought the machine. Using a lower speed is no go.
Hmmm, wondering if you are using the correct needle for your project.
All About Needles
In addition, when you thread the top thread, ALWAYS raise the presser foot so the thread will seat properly in the tension disk. You may also want to verify that the thread path is correct.
Feb 08, 2017 | Sewing Machines
Most of the time the bobbin stitch is correct. Occasionally there is a loop in the bobbin thread. Any suggestions as to what this could be?
Is it actually the bobbin thread that loops or is the loop appearing on the underside of the fabric as you stitch? If it is a loop under the fabric, that's usually an indication it is an upper thread issue. Thread irregularities that appear on the topside of the fabric are generally bobbin related.
First thing to try is installing a brand new needle. Verify it is the correct needle for the fabric and thread being used.
All About Needles
Sometimes, the fabric being stitched will "grab" the thread and hold it for a second before releasing and will cause a loop. In this case, a needle with a larger scarf and eye may be helpful.
You might also open the upper tension as much as possible, RAISE the presser foot and run a piece of UNwaxed dental floss through the tension disk a few times to clear out any gunk that may be stuck there. A piece of pearl cotton dipped in rubbing alcohol and squeezed moist/dry will also work.
Remove the upper thread. RAISE the presser foot and rethread the top thread from the beginning. Use only fresh, good quality thread--NO old or bargain bin variety! Try using the same thread in the top and bobbin. Make sure the thread is firmly seated in the tension disk and the thread path is correct. Check that there are no burrs or snags in the thread path that could be catching the upper thread. Especially, check that the thread is not catching on the spool "slit" that holds the thread when in storage. Every time the thread navigates around the thread spool, it could be catching on that slit just enough to cause a loop.
Try changing the bobbin. There could be something amiss with the current bobbin--could be nicked or could even be the wrong bobbin for the machine. Also, make sure the bobbin is loaded and turning the correct direction in the machine.
Set the upper tension to the midway point. This is usually the starting point, although it will probably require some tweaking. Test your stitch and adjust the tension so the upper and bobbin threads meet in the middle of the fabric. Neither thread should dominate one side of the fabric or the other.
Understanding Thread Tension Threads
Last thing to try is a different presser foot.
If you still have the intermittent loop, you might want to take it for service. Could be a problem within the tension disk.
Nov 05, 2016 | Sewing Machines
I am using the walking foot for a quilting project that I am working on, however, the bottom stitching is just looping and can just be pulled away from the fabric.
Be sure you are using a brand new needle.
Remove the thread from the machine.
ALWAYS RAISE THE PRESSER FOOT and rethread the upper thread from the beginning. Make sure the thread path is correct.
Verify the bobbin is installed and turning the correct direction in the bobbin case and that the bobbin thread is threaded through the bobbin tension mechanism.
Set the upper tension to the midway point between high & low number--this may require some adjustment for your particular machine.
Pull the bobbin thread to the top of your sewing project before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Re-test your machine on a scrap quilt sandwich (make sure the walking foot is installed correctly and that the presser foot is lowered when beginning to stitch).
Consult the owner's manual for instructions for presser foot pressure. The pressure may need to be adjusted because you are dealing with a sandwich that is thicker than regular fabric.
You may also try changing the type and size sewing machine needle you are using. Using a Top Stitch or Microtext needle will help the needle to penetrate the fabric sandwich easier. A Top Stitch needle has a larger groove to protect the thread as it pierces the fabric which helps prevent looping.
Also, verify the thread is not too small for the needle's eye.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwil1tu2mb3PAhVR6mMKHUlvB_4QFggoMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Oct 02, 2016 | Sewing Machines
The top stich is loose on my Janome Harmony 8100, I have cleaned and changed bobbins, but nothing seems to help.
Ok, Let's understand exactly what is going on. You said. "the top stitch is loose." So that we are clear....do you mean that you are getting loops on top of the seam? Or do you mean that you are getting wiggly stitches on top and small loops on the bottom of the seam? It's important to know... Because loops underneath means the top tension isn't right. Maybe you didn't thread with the presser foot in the UP position... or your tension is dialed too low.
Now, if you are getting loops on top of the seam... that means the top tension is too tight. Loosen the top tension. Make sure your bobbin is inserted correctly. If loosening top tension isn't enough, you may have to tighten the tension screw on the bobbin case/ or bobbin carrier.
Feb 25, 2013 | Janome Memory Craft 9000 Computerized...
I am just making a regular straight stitch and the thread on the back of the fabric is looping ALOT! what am I doing wrong
change the needle
make sure the bobbin is inserted correctly into the bobbin case
make sure the top thread has not come off the thread take up lever
also try adjusting the top thread tension
Sep 01, 2012 | Singer CE-100 Futura Computerized Sewing...
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
Good day!
Jun 07, 2011 | Brother CS-6000
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Thread tension problem when sewing on heavy fabrics
Sometimes when I need to use heavy thread for top stitching to reinforce a seam that has come undone, I will use the heavy thread on the top and regular thread on the bottom. I haven't tried it the other way around for hemming but I would think it would work. I do not currently have a Bernina.
Jan 15, 2008 | Bernina Artista 180
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
