Question about Welding Tools
My welding machine will not idol down .Only stays in high idol. Why won't my machine idol back down when not welding? Yes I have the switch on run / idol lol 225 bobcat miller Kohler engine
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 35 Answers
Possibly the idler control circuit board. I changed out my fair share back when I worked on them. Also, check your idler solenoid. I can't remember if those pulled in to idle, or pulled in for high RPM's. May be something as simple as rust on the solenoid plunger.
Posted on Jan 02, 2015
  • 100 Answers
SOURCE: i own a miller bobcat 225 nt where can i buy a
miller for less.com
Posted on Feb 15, 2010
  • 18 Answers
SOURCE: Bobcat Miller 225 won't start.
Check the oil safety switch maybe it is bad. It will stop running if low on Oil or wont start.
Posted on Feb 19, 2011
wentlanv
  • 710 Answers
SOURCE: How do you drain the
Hi pplmelita,
If you don't have a petcock to turn the fuel off below the tank, I would disconnect the line at the filter and drain the gas out that way.
If you're wanting completely drain all old gas out, drain as above and then run until dry.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 14, 2011
  • 4 Answers
SOURCE: how to separate the kohler engine from the
The shaft is tapered and will have a bolt in the center, loosen the bolt enough so you can tap on the end of the bolt. This should release the shaft, if not there should be 2 hole that you can thread a bolt into to push the connection apart.
Posted on Jun 26, 2011
luis_david
  • 407 Answers
SOURCE: Why is my bobcat 225 not welding hot enough?
If all your settings are correct and still not hot enough probably your fuse F1 is open and need to replace. Check page 42 of the owner's manual for instructions.http://www.millerwelds.com/om/o4434q_mil.pdf
Hope this fix your problem.
Posted on Nov 30, 2011
My welding machine will not idol down. Only stays in high idol . Why won't my machine idol back down when not welding? Yes I have the switch on run /idol lol 225 bobcat miller Kohler engine
put 12 volts to the coil and see if it pulls in. Could be coil, idle module, ignition switch, or wiring. Get a 12v test light and trace it.
Dec 15, 2014 | Welding Tools
I have a miller bobcat 225 is lower power while welding, any idea?
First off, check all of your welding cables to make sure they're in good shape, then check for tight cable connections. Is your machine staying at low idle speed while trying to weld? If so, Switch the idle select into the 'weld' position and make sure the high RPM's initiate. Try welding again. Better? Could be a number of things, if not.
Dec 12, 2014 | Bobcat Miller 225 Welder Generator 907209...
Is fan motor on welder to come on at powering up or only when it gets hot
the machine i use for work will only come on after it gets hot and shuts off once its cooled down
Mar 03, 2014 | Welding Tools
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
I have just purchased an T10604R to operate my two speed pool pump and wired it just as the instructions said, but when I operate the T106 timer which controls the high/low to the pump and switch it to...
Yes I would say you are correct...the switch may not be rated for the amperage of the pump and caused the 1-2 contacts to weld together...
before replacing the timer with a like model be sure to check the amperage of the pump and the rating of the switch to make sure your not running too much current through that switch.
heatman101
Aug 16, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Bobcat 225, machine is idling way to high and will not idle back or shut down when switched to off position. Could this be the soleniod on top of motor connected to throttlelinkage?
It could be and the governor sticking to wide open throttle, try the linkage at the full fuel position with the engine off and see if it sticks when in full fuel mode, there could also be an intake leak but would not cause it to run with the switch off that is a different problem. let me know if you need more help.
Nov 27, 2009 | Welding Tools
Idols high when comming to a stop wont idol down
Sounds like you have either a carb with a sticky slide. Pull air box and look down carb throats while twisting throttle (assuming the bike is not EFI)
Jul 20, 2009 | 2003 Yamaha YZF 600 R thunder cat
High idol all the time& tranny problems
Check for vacuum leaks on the high idol. You have a speed sensor or wiring issue with the tranny. Will need to be checked somewhere with a computer to know for sure on the tranny.
Jun 08, 2009 | 1994 Chrysler Concorde
Snap On Ya219B No Spark
The transformer has an overtempature switch the shuts the welder down when its duty cycle is exceeded. After it cools, the switch will close and the welder will run again. However, you are not supposed to use the welder until waiting an additional cooling off period as specified in you manual(~10 min.).Also you are not suppose to weld beyond the duty cycle or damage could result. Especially if done on a continuous basis.
Apr 10, 2009 | Hobart Welding Tools
Welding Tools Logo
224 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
