Question about Hoover Washing Machines
Stain blaster and stop light continually flashing no matter which programme selected after cleaning blockage from pump
I have a VisionHD VHD 814, earlier I had a problem with it running but not draining out. After laying it flat on its side and removing all hoses to the pump I found that a small plastic sword was stuck, I removed re-attached hoses. Stood machine up then turned on water and power selected a short programme and now have stain blaster and stop continually flashing
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
  • 1462 Answers
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
Posted on Jun 29, 2008
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
  • 901 Answers
SOURCE: Removed both water pump hoses, No blockages drum
Water pressure switch adjustment or clogged. Check the small connecting hose to the switch body.
Final spin command signal generates from this part only.
Posted on Mar 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Candy washing machine has
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
The diswashing programme starts intermittently and does not go to the end of the washing programme and the washing is luke warm. I have checked and cleaned all filters and checked the water...
I suspect the pump or outlet hose is partially blocked, is it emptying in normal time with a normal outlet flow? (You can check that by watching the water come out if you can see the drain). Does the flashing light have a label on it, the lights on miele are generally labelled.
When you say it starts intermittently do you mean you have to start it more than once to be successful? That again would point to a pump or outlet hose blockage as it has to purge any water before starting.
Difficult to diagnose without more clues.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Miele Dishwashers
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hoover visionHD vhd 842-80 will not complete its cycle (does not spin) lights flashing are 1200 &time saver button
Mine done the exact same thing and it was the bushes that went not the pump, so you can change them your self if you can
Nov 07, 2010 | Hoover Washing Machines
Washing Machines Logo
110 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
