Question about Toshiba DVR620 DVD Recorder/VCR
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
PROBLEM: [3 of 4 HDMI Video images & DVD recordings vertically pinched.] Progressive: ON & OFF; set to ON. Aspect Ratio: Auto, 4:3, & 16:9; set at 16:9. Inputs L1 & L2; set at L1, Dubbing VCR to DVD. Recording compatible ON. HDMI Format to RGB. [TV & recorded DVD images] are the same; Height correct in HDMI selection 740x480, and [[vertically pinched in 1280x720,1920x1080i, & 1920x1080]]; set at 1920x1080i. DVDs also, vertically pinched when played on another DVD players & this unit. Changed output HDMI cable to a Hi Quality cable. No improvement. Connected 3 different TV's, SONY 50", SAMSUNG (Older 27" & New 55" SMART TVs), still vertically pinched. VHS to DVD works OK except for the 3 HDMI vertically pinched output. Tried different mfg's of blank DVD & DVD-R & DVD+Rs. Purchased DVDs play correctly FULL height in all modes. HELP, JIM jbenham10@cox.net
    Champion:
  • 236 Answers
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Posted on Dec 16, 2014
    New Friend:
  • 4 Answers
Download and install Appvn for PC on for using the premium apps Appvn APK Download for Android & iOS App Free ' English where you could locate the applications of iphone.
Posted on Nov 29, 2017
I have a Samsung C230 LED monitor and I'm wondering if I can use it with a Roku XD/S in place of a TV via the hdmi cable?
as far as i can tell this monitor is not HDCP compliant ( High Def Copy Protection ) and therefore will not be suitable as a TV monitor. Computers can use non HDCP compliant monitors but TV Tuners, Satellite Receivers, DVD players etc with HDMI are HDCP compliant and must have a HDCP display... HDMI has two formats basically HDCP and non HDCP
Sep 04, 2013 | Samsung Syncmaster 940BW LCD Monitor
Recorded dvd from my toshiba dvr620ku won't play on other dvd players
it could be the video format from the recorded dvd's not compatible in the dvd player that you have been used.
Aug 03, 2012 | Televison & Video
Hi how can i modify the crt monitors yoke for a tv circuit.
Flat panel TVs don't have a yoke - that's the deflection coil for a Cathode Ray Tube (CRT) as used in older non-flat TVs. Some CRT TVs and monitors had flat screens (i.e. the face is flat) but the overall package isn't.
So I'm not sure what it is you want to do. If you are trying to get a computer monitor to display TV signals, use a video capture device (there are many). Some work with a computer, some don't. But you can't just feed the video into a computer monitor unless it is made to take it (usually with an RCA or BNC connector vs. VGA, DVI or HDMI connectors).
Aug 31, 2011 | Televison & Video
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
White screen and black vertical lines over half of la26b450 model tv screen
Good day!
that problem is on the cable please try to play dvd or recorded tv shows.
if you play dvd or recorded shows and picture is normal
try to check the connection of your cable and try to touch the connector and move it gently then see the picture of your TV if there's changes
thank you
May 29, 2011 | Televison & Video
Trying to connect 46"samsung smart
200px-multiconnector-scart-chti.jpg magnify-clip.pngMulti-AV SCART adaptors with Input/Output signal switch (gold & nickel). A common misconception among game console owners is such connectors will allow RGB quality, while they are only CVBS and S-Videocompliant. THESE CAN BE USED FOR NON HD DEVICES SUCH AS YOUR DVD-VCR, AND SKYTOP BOX YOUR TV WILL HAVE AT LEAST 1 OF THE YELLOW WHITE RED COMPOSITE CONNECTION
May 05, 2011 | Computers & Internet
My recorded is linked to a tv with a Freeview box in the tv, but I cannot record Freeview channels as it receives via the annalogue connector. I'm not technical - how do I overcome this?
if you TV has a feature called "Monitor" out, then you can take a "Feed"out, via, The AV, link, the Yellow, Video, Red & White Audio. wiring color to color, and selecting EXTERNAL IN on VCR. If this feature is available, whatever is on screen, is displayed out of that "Monitor Video & Audio Socket"
Get a TV manual and a VCR and have a look it will show you how.
Mar 23, 2010 | Panasonic DMR-EH50 DVD Recorder
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Non-HDCP Compliant Error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
Jan 06, 2008 | Protron PLTV-32 Television
Display Image Pinched Vertically
I think this is a non-ddc monitor. But I think you right, the monitor is damaged and won't read it's own driver. http://support.microsoft.com/kb/162737/en-us
Jul 11, 2007 | NEC MultiSync XV17 17" CRT Monitor
Toshiba DVR620 DVD Recorder/VCR Logo
224 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
