How do i select the channel menu
In the channel menu the cursor jumps through the option to retune the digital tv
  • 3,289 Answers
Many times the re-scan tune option goes away if you've selected an input on the TV other than the "tuner", "Antenna" or similar (ie: AV1, HDMI1, Sat, Cable, etc.do not make use of your TV's internal tuner).
Make sure you select an input on your TV, ( tuner, etc.) that will use the tuner and have an antenna or non-digital Cable TV coaxial cable connected. Then attempt to scan again.
Posted on Dec 15, 2014
How do you tune TV
A full retune should only takes a few minutes and can be done with your remote control. Here are some guidelines for how to do it, but bear in mind every model of digital TV or box will be a little bit different.
  • Make sure your Freeview TV or box is on and in digital mode, usually by pressing the DTV or digital button on your remote. Then press 'menu'.
  • Select the 'set up' or 'installation' option. If you see picture icons, select the tool box, satellite dish or spanner. If you are prompted for a code, try 0000 or 1234.
  • Select the full retune option. This is sometimes called 'first time installation', 'factory reset', 'default settings' or 'shipping conditions'. Do not select 'channel update' or 'add channels'.
  • Press 'OK' if your equipment asks if you want to delete all your channels. Don't worry this is normal
  • Channels will automatically be installed. This may take a few minutes and your equipment may shut down and restart
  • In some cases, where transmitter signals overlap, it may be necessary to carry out a manual retune.
Note: Depending on your TV equipment, you may need to update your favourites list following a retune. Some digital recorders may require scheduled recordings to be reset.
Jun 10, 2016 | Televison & Video
How do I get digital channels instead RF channels on my TV DWM32H1G1
Have you hot a digital receiver connected to the TV.....Sky or Cable?
Jan 02, 2015 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
I cannot retune my samsung tv- model no LE37C53CF1W- COULD YOU ADVISE HOW TO RETUNE, mANY THANKS, Jim Lauder
Hi,Does the icon look like a large satellite dish?
Make sure your TV is on "TV" and not "DTV" before retuning.
To re-tune analogue channels:
I have a Samsung TV and that icon is not accessible from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
(on your remote, you should have a button with TV/DTV on it)
To re-tune analogue channels, if you want to re-tune digital channels, then look for the "D MENU" button on your remote. Press this then scroll down to the icon that looks like a large satellite and then on "Auto Store" This will re-tune your digital channels :0)
Take care and hope it helped.
May 28, 2011 | Televison & Video
I bought a TOSHIBA 32KV500B tv. At the Initial Installation mistakenly I selected "yes" for 'do you want to search analogue channels?' guestion. And then I lost all my automatically selected...
I had this problem and searched the internet for hours looking for an answer and was given the initial same reply as this and it does not work. To solve this problem all you simply need to do is press source button on the controller followed by pressing the DTV/USB option. All your digital channels will come back to you and you will find the menu setup options you are looking for!!!
Feb 12, 2011 | Toshiba Televison & Video
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Sep 29, 2009 | Samsung Televison & Video
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Oct 16, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
