Question about Freezers
How to get free Manuals for an old freezers?
He is working but not efficiently, I m trying to fixit here in chile but i need any kind of informations. Only have a dark electric diagram ...I know haow to repare principal items.Thanks
How to find a manual for Frigidaire Freezers
If you have a PC try going up to the Frigidaire Website. If not call them on the phone and ask if they have a manual available for your model refrigerator. So you'll need the model # for the right manual. There are also other websites that sell (some may be free so look around online) manuals. Manuals.com has manuals but most of them are not free. Always check the manufacturer first as those manusal should be free.
Sep 02, 2014 | Freezers
Was offered a new energy efficient freezer 16.7 cu foot standing frost free by Fridgidaire ( energy efficiency rating 65). My 13 yr old Kenmore: Model : 253.9287215 Freezer works fine. Is it rated the...
I was not able to find any info quickly on your older Kenmore in my literature but its a sure bet that it was not as efficient as the new one. You can do a calculation or look at the plate (usually on the back) that states the amperage draw on each model- the higher one is the less efficient. As for cuft you need to do the math and measure the inside storage area in inches wide, inches deep and inches tall. Multiply the width X depth X height then divide by 144 (the cu inches in a cubic ft) this will give you the actual size of the Kenmore for comparison. Hope this helps... also you may want to check with your local electric utility company as many are offering a rebate to replace 10 yr old fridge. freezers and usually pick up for free.
May 15, 2014 | Freezers
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
Feb 01, 2014 | AEG Freezers
Only one half of my chest type freezer freezes? It is old. Bought at least 18 years ago. Help!
My recommendation is to get rid of this 18 year old freezer as it is costing u a fortune to keep it plugged in. Then ask yourself if you really need an additional freezer at all?? If you do, consider purchasing a new small one that is really energy efficient. You will be way money ahead I assure u.
Apr 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Need correct setting for 30 yr old upright Kenmore freezer
depend on the type of control you have on your box ,,,, best is if it shows 1-7 set it on 3-4 ,, if it has letters set it on C ,,, eather way set the control on mid-point and it will work fine.
Larry
Nov 22, 2008 | Freezers
Kelvinator Chest Freezer will not cool after spray painting rust spot.
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Oct 10, 2008 | Freezers
Commercial reach in freezer
Hi scondon15,
I just read this article about the subject you ask about!
How old is the freezer?
Repair or replace?
When to pull the plug on your old refrigerator and or freezer
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
Note that refrigerators under warranty might require service from a factory-authorized technician;
If your refrigerator is out of warranty and is four to seven years old,
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
of a refrigerator you replace is likely to end up in a landfill.
Thank You, HUUUM
Sep 19, 2008 | Piper Products Freezers
Freezer door left open
Hello Captain rose,
Did you turn off the freezer and then pull the plug?
Try this again. Turn off the freezer then pull the plug for 4 minutes, plug it back in and turn it on.
Do you hear the compressor turn on?
It should only take 24 hours max. to get back to full temperature!
If this does not help and you hear no compressor, especially if it is an old freezer .
They may have burned out the old compressor by causing it to work 2 hours straight .
Rather than cycling off and on every half hour or so!
If it was an old freezer, so it means it was on its last legs and would have happened some time soon any way!
Here is an article I read abut the age of refrigerators and freezers.
Repair or replace?
Thank You, HUUUM
Sep 17, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer not freezing
Hello jannette859,
huuum at your service
You said,
freezer was working fine had to unplug it due to evacuation, now it doesn't freeze, is there any reset buttons? i didn't turn the temp selector to the off position before unplugging
Try turning off the temp. switch off.
Then plug it in and turn the temp on!
this may reset it.
Repeat one more time and let me know ho it went!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Bless You huuum
Please give me the best rating at fixya .com before you sign off.
Thank You
Sep 15, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Hotpoint Mistral fridge freezer frost free Model 8596P
Hi Avaline,
You need a new friend!
If the unit is 10 years old or more it does not pay to fixit! the new ones will save you big time energy!
OR,
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 21, 2008 | Freezers
Freezers Logo
51 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
