Question about Samsung WB30F Smart Digital Camera, Red - Bundle - with Lowepro Dublin 20 Camera Pouch, 8GB SDHC Memory Card, Microfiber Cleaning Cloth
How do I turn ptp off on WB30F
Turning off and holding menu and picture down and turning back on
SAMSUNG WB30F PTP MODE
How do I get the camera out od ptp mode.
Sep 19, 2013 | Digi Computers & Internet
How do I disable the PTP mode in my Samsung ST150F smart Came
TO CHANGE THE PTP MODE OFF IN SAMSUNG ST150
1) Turn the camera off
2) Hold the zoom out (-), flash button( PHOTO TAKING) and the Menu button.
3) While holding, turn the camera on.
4) When the camera turns on, it will show a text screen
5) You can let go of the zoom out and the Menu button
6) Press the Menu button
7) Press left. This will turn PTP Mode off
8) Turn the camera off and on, and you're good to go
Aug 21, 2013 | Samsung ST150F Smart Digital Camera Red
I couldnt able to copy from my sony camera to my pc
RE not being able to USB function on Sony Cyber Shot camera connecting it to TV....solution was to change USB Mode on camera from PTP to AUTO.
Turn on camera, press home button. Click to Main Settings 1 and then use down arrows to go to Main Settings 2. Highlight USB MODE PTP, and use right arrow to change setting to AUTO, and press Home button to exit.
Apr 21, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
Garmin 2720 keeps dropping the satellite connection
Turn unit off hold down menu button while turning unit on and, hold button down till a white page comes up that says general.
This this the testing mode if it is not testing then press the menu button, after test is down press menu button a couple of times and it will go to another testing, continue to the end turn power off then back on and should work.
May 26, 2010 | Garmin StreetPilot 2720 GPS Receiver
Can't find satelite
Try resetting the unit is helps in more problems
Apr 27, 2010 | Garmin StreetPilot 2720 GPS Receiver
DSC-S730 copy my picture to my computer?
The procedure to transfer pictures to a Computer depends on whether or not the Camera has the capability of using Picture Transfer Protocol (PTP). If the Camera is capable of PTP (in this case; DSC-S730 - YES), set the USB mode in the Camera menu to PTP and then use the PTP procedure to copy the pictures to the computer. Otherwise, use one of the standard USB transfer procedures.
This procedure must be performed while logged in as Administrator or to an account with Administrator rights:
  1. Turn on the Computer.
  2. Turn on the Camera.
  3. Insert the recording media containing the pictures into the Camera.
  4. Set the USB connection or Transfer mode setting in the Camera menu to PTP .
  5. Use the USB cable supplied with the Camera to connect the Camera to the Computer. NOTE: Connection through a USB hub or other USB device --such as a printer or keyboard-- is not supported and cannot be guaranteed. The Camera should be connected directly to a USB port on the Computer.
    NOTE: The Scanner and Camera Wizard should automatically start.
  6. In the Scanner and Camera Wizard window, click the Next button.
  7. Under Choose Pictures to Copy , do one of the following:
    • Click to select each picture you want to copy.
    • Click Select All to select all the pictures for copying.
    NOTE: Selected images will be marked with a green check mark.
  8. Click the Next button.
  9. Under Picture Name and Destination , in the Type a name for this group of pictures field, enter a name for the folder where the pictures will be saved.
  10. Next to the Choose a place to save this group of pictures field, click the Browse button.
  11. In the Browse for Folder window, click to select the location on the computer where you want to save the pictures.
  12. Click the OK button.
  13. In the Scanner and Camera Wizard window, click the Next button. NOTE: The pictures are copied to the Computer.
  14. After the transfer process it finished, under Other Options , click to select Nothing, I'm finished working with these pictures .
  15. Click the Next button.
  16. Click the Finish button.
If you are still unable to transfer pictures, please switch the USB mode of the Camera to Normal or Mass Storage and try again.
After following the steps above, the pictures from the camera should successfully be copied to the computer. If for some reason the pictures did not copy, try using the method for standard USB picture transfer.
I'm assuming you are using the Windows XP Operating System in the Computer. If not then follow this link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C116935
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Power up trouble
Okay i will need you to turn off you system off from the main power located on the back. Then you will need to turn it back on after that you will need to hold the touch senstive turn on located on the front of the ps3 hold it. You will hear a beep that just tells you that it is turning on. Still be holding the turn on button untill you hear another beap after that you can let go. This will reset you picture setting and will not delete anything on your hard disk. If this dosent work call sony at 1 800 345 7669
Mar 19, 2009 | Sony Playstation 3 (PS3) Console
Uploading pictures back onto my camera
Set the camera to MTP instead of PTP in the settings menu on the camera. This will allow it to operate as a USB device instead of only interacting with the Nikon software.
Specifically...
Hit menu on the camera, go to the setup menu, and select USB and then make sure it's set to "Mass Storage" and not "PTP". Then connect the camera.
Hope this helps.
Jul 25, 2008 | Nikon Coolpix L11 Digital Camera
My XT will not connect to Vista.
Well, that worked perfectly. Turn on your Rebel XT camera and under Menu then Tools go to Communication and set it to Print/PTP. Thank you to all you very smart people!
Dec 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Samsung WB30F Smart Digital Camera, Red - Bundle - with Lowepro Dublin 20 Camera Pouch, 8GB SDHC Memory Card, Microfiber Cleaning Cloth Logo
41 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
