Question about Kitchen Ranges
I have f10 code
Nothing
F10 fault
F1 through F10 fault codes are runaway temperature codes.
If this error code is shown while the oven is in day time mode, the Electronic Oven Control (EOC) would need to be replaced. Otherwise it may be the oven temperature sensor or Resistance Temperature Detector (RTD sensor).
Sounds like you will need to contact an appliance repair technician in your area to test each to isolate the problem.
Apr 13, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Gaggenau over eb 270 error code f10
hello i m french f10 is a problemn of the temperature sonde that give gou the temperature of your gaggenau
May 26, 2012 | Ovens
Acer Aspire One D250-08K Need to restore to factory settings and i have no disc. Screen is black. On start up pressed ALT F10 then nothing happens
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Aug 29, 2011 | Acer Aspire One PC Notebook
The front panel keeps showing F10 Err message ?? And it won't stop beeping, any idea what it could be??
The F10 error code means that was a runaway over heating that occured in the oven. The things that could cause the over to overheat to the exterme of the F10 error code reqirements is during self clean normal cleaning temp. IF it wasn't cleaned just before the F10 error code,first the oven temtature sensor needs to be replaced then if F10 comes back after the sensor is replaced the computer control board needs to be replaced.
Gene
Aug 16, 2011 | Kenmore 46713 Stainless Steel Electric...
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
