Replaced the latch unit which was broken. Checked wires for rust or damage but did not find any. No loose connections.
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
SOURCE: Won't start. Light on next to "heated dry" button & "#3" graphic
You have the lock activated. press and hold the HEATED DRY button for 3 seconds
SOURCE: control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
SOURCE: my maytag 200 quiet series dishwasher has a button
The control panel has bee locked. Press and hold the heated dry button for 3 seconds until the light next to the lock "3" button goes off. This feature is to prevent small children from starting it. Locking the controls works the same way, hold the heated dry button for 3 seconds will turn it back on.
I understand that this means the control panel is locked. The suggestion to press the aheat Dry button for 3 seconds does no work. Any other suggestions?
