Question about Adobe Illustrator CS3 - Windows for PC (26001797)
How to repair illustrator file?
Hello, can u help me.. So I have an error when opening Illustrator File = Offending operator: "Bg" I have an Illustrator file that I created and I made a change to a gradient and then saved the file. Is there a way to repair this file? Thanks.
    Problem Solver:
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
http://www.illustrator.repairtoolbox.com/
Posted on Dec 17, 2014
    Problem Solver:
Hello) May be this steps can help:
    ·Open the file (if possible) and print as a Postscript file by choosing "File > Print," then choose "Adobe Postscript File" as your printer and click "Save." Open the exported PS file in Illustrator.
    ·Select "Object > Path > Cleanup", then go to the "Layers Panel" menu and select "Paste Remembers Layers." Select the artwork and copy, then paste into a new file.
    ·Launch Adobe Acrobat (any version except Reader) and attempt to open the Illustrator file from within Acrobat. If it opens, make a minor edit using the "Select" tool (if possible). Save as a PDF and an EPS,and export as an EPS by clicking "File > Export > Postscript > Encapsulated Postscript." Open these files in Illustrator, or place them into a blank file if opening fails.
    ·Eliminate potentially corrupted elements (swatches, brushes, symbols, links, fonts) one at a time and save the file (under another name) to isolate the issue; reinstall the fonts, create outlines, select all elements and convert to process black. Delete all imported elements and custom elements, such as symbols, and remove custom brush strokes.
    ·Open Illustrator (the same program version that was used to create the corrupt file); save a blank file in the same format (AI or EPS). Close the file and change the extension of both to TXT (not necessary on Mac) and open in a text editor, such as Notepad. Note the point in the corrupt file where the valid data begins: it will be numbers and letters rather than symbols. In the good file, find "%%BeginData" and copy all data before it, then replace the bad data in the bad file. Save, close, and change the file extension back to AI or EPS, and try opening.
    ·Open the file in Photoshop or place into a new blank page in InDesign. This may enable you to salvage text or critical file elements, which you can export back into Illustrator.
    ·A final resort is to purchase a third-party program or service that salvages damaged files. Some options include Recovery Toolbox, Bad Copy Pro and Corrupted File Repair (see Resources).
    Also advise you to use Illustrator Repair Toolbox
    Source:http://www.illustrator.repairtoolbox.com/
Posted on Dec 16, 2014
Adobe Illustrator file
Hello Philip.
Try a special program Illustrator Fix Toolbox https://www.fixtoolbox.com/illustratorfix.html
If it couldn't aid you:
1) Open the preferences file and look for the entry named "enableContentRecovery", change the value from 0 to 1. This turns on the feature.
2) Launch Illustrator and choose "File>Open". Select the file from which you wish to recover the roundtrip information.
3) Click "OK" .
Aug 13, 2016 | Adobe Computers & Internet
Adobe Illustrator file format is having difficulties
There may be a TMP file in the same folder, you can try renaming it to AI and see if this opens. Helped me on a couple of occasions but also has not worked in the past.If it useless, there is a good program: Illustrator Fix Toolbox https://www.fixtoolbox.com/illustratorfix.html
Jan 29, 2016 | Adobe Illustrator CS2 for PC
Illustrator Error
Use Illustrator On-line repair service service will analyze the contents of your file, the internal data structure of the *.ai file in an online mode using a combination of intelligent algorithms. It will then provide you with a preview of recoverable project data. The service features a very clean an intuitive interface, which makes corrupt Illustrator file recovery a snap even for novices.
For more: https://onlinefilerepair.com/en/illustrator-repair-online.html
Nov 27, 2015 | Adobe Illustrator 10.0 for PC
How to fix adobe illustrator?
Maybe try repairing permissions, restart, and try to open the files. This might work.
Also u can repair illustrator file owing Illustrator Repair Toolbox I found it here
Jun 06, 2015 | Adobe Illustrator CS2 for PC
Damaged File Error while opening AI file
Try:
Illustrator On-line repair service. Our service will analyze the contents of your file, the internal data structure of the *.ai file in an online mode using a combination of intelligent algorithms. It will then provide you with a preview of recoverable project data. The service features a very clean an intuitive interface, which makes corrupt Illustrator file recovery a snap even for novices.
For more information: https://onlinefilerepair.com/en/illustrator-repair-online.html
Mar 02, 2015 | Adobe Computers & Internet
How can i fix adobe illustrator damaged file?
Hello. One thing to try is to create a new document and see how much, if anything, can be rescued if you try to File>Place the damaged one.
Or its better solution to use Illustrator Fix Toolbox.
See more: http://www.illustrator.fixtoolbox.com/
Dec 21, 2014 | Lenox Serveware, Holiday Illustrations...
Adoobe Illustrator problems
Correct the offending command
1.Launch Illustrator.
2.Using File > Open, hold down Command + Ctrl + Alt + Shift (Windows), and click Open. Double click the file to open. You want the full Open dialog.
3.Your file will be blank. Close the file without saving or altering.
4.Go back to your directory. You will now have a second file with an underscore at the beginning of the filename. (myfile.aivs._myfile.ai).
Nov 03, 2014 | Adobe Illustrator CS2 for PC
Saved illustrator 10 file gets corrupted
Check for a damaged pattern, gradient, or custom color
To determine if the problem is caused by a damaged pattern, gradient, or custom color:
1. Choose Edit > Select All and change the fill and stroke to process black.
2. Perform task 4 again to determine whether the problem occurs in a new file that does not contain the patterns, gradients, or spot colors. If the problem does not recur, re-create the pattern, gradient, or spot color in the original file.
Otherwise:
First option: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/383-%E2%80%8Bcorrupted-fonts-in-illustrator-file-urgent-help-need
Second: shareware tool Illustrator Repair Kit
See more about:- http://www.illustrator.repair/
Oct 27, 2014 | Adobe Illustrator 10.0 for PC
I cant open a new file, template or old file. My Illustrator CS just crashes. Please help
Double click on My Computer on your desktop and open C:>Documents and Settings > User >Application Data > Adobe > Adobe Illustrator CS2 Settings. (Your version of Illustrator will be in the foldr name.) Inside this folder is a file called AIPrefs. Drag this file to the trash, and restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
You can also reset Illustrator's preferences by holding down Shift + Control + Alt while launching the program. If you get a dialog asking if you want to delete the Adobe Illustrator settings folder, click yes to proceed. Restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
Dec 21, 2010 | Adobe Academic Illustrator CS 11 for PC,...
Adobe Illustrator CS3 - Windows for PC (26001797) Logo
149 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
