Question about Dryers
1 remote for Fasco Charleston ceiling fan model 438
Will this remote take care of my ceiling fan #99500
most ceiling fans run at certain frequency around 2.5khz
i do have sound bar that can run my floor fan,
go to local hardware store with fan information and they sale most remotes there and the remotes need to be programmed most of the time depending what features you fan has.
my fans has 3 speeds, led light remote turn on and off, pull chain turn fan light off or on, forward and reverse modes
www.ask.com/mfg.name/make/model/ceiling/fan/#99500/needs/remote/replacement/
www.ceiling.fan.wow.com/mfg.name/services/parts/telephone#/
Oct 22, 2015 | Dryers
What remote goes with ceiling fan model YG-241?
This is some kind of generic ceiling fan that used some kind of remote. Finding a replacement remote will be difficult to impossible. A more practical approach would be to replace the fan.
May 16, 2014 | Hampton Bay Dryers
Ceiling fan has no remote, does not work with switch
Home Depot/Lowe's etc have a remote kit specific to ceiling fans. your universal remote may not be compatible with your specific type of remote sensor that is up in the base of your ceiling fan. Check a user's manual to see the specifications of your specific Model # of fan to see what requirements they set for it. You would probably be better off just getting a new kit for an average $12 to get it working again.
Wish you luck.
Mar 10, 2011 | Universal Remote Control Hampton Bay...
I need a wiring diagram for Fasco model #659 serial # 447621 ceiling fan, heater, light unit.
Yellow wire is light. Blue is vent. Red is heat element and fan after going through a circuit breaker and thermostat. Brown is night light. White is common to ventilator housing. Black is power to switch cluster.
Jan 25, 2010 | Fasco Dryers
Heritage Ceiling Fan
You can try a univeral remote and that should work. You can buy one online at: http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
Jul 10, 2009 | Dryers
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
Dec 10, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Remote control, changed battery, still nothing
You can also try ebay for OEM replacement fan remotes for various brands including Hampton Bay...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
61 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
