Question about Whirlpool Refrigerators
Fridge defrosting to often resulting in water build up in back of fridge
Clearing drain outlet
  • Whirlpool Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Units are designed to go into a defrost mode every 8-10 hours, where everything will shut down with the exception of your lights. Your defrost heater will turn for 20-30 minutes, and then your unit turns back on.
Normally, water build up is due to a frozen condensate drain, where the drain is frozen and the condensate (Water) has no where to go except for the bottom of your freezer.
If your drain is clear, then you have a major problem, Unplug your unit. Remove the back cover of your freezer. In the upper right hand corner of your freezer coil, you probably have a block of ice. This means that you have a seal system restriction. The is a small tube about 1/16" in diameter with a small needle size hole through it. Here is where restrictions generally occur.
A repair of this nature is about $450.00 or more.
Sorry for the bad news.
Posted on Dec 24, 2014
    Problem Solver:
  • 6 Answers
I do not believe defrost cycle is too frequent if anything not frequent enough after all you are trying to eliminate the frost , which can build at a given rate depending on a variety of things ie humidity sad so on. well when you defrost it produces water which is taken care of by evaporation sometimes the evaporator is a pan placed under the refrigerator if the pan is removed the water ends up on the floor, anyway I would check out the evaporation system.
  • 1462 Answers
SOURCE: Auto defrost not working correctly
the tray at the bottom which collects defrost water usually has its own heater or a section of the main heater runs close to it. check this part of the heater has continuity. an old trick as well which sometimes works is to wrap some copper wire round the heater and lead this to the drain hole. conductiuon of heat thro the copper helps keep the drain clear. this is a common problem across all makes
Posted on May 08, 2007
  • 168 Answers
SOURCE: Fridge water "overflow" ?
It is supposed to drain to a plastic tray under the fridge. There is usually not a lot of water that drips down there... and the water usually will evaporate before overflowing.
If the water is draining on the inside of the fridge, then the drain tube on the rear of the fridge might be clogged. You should be able to remove the tube fairly easily, and then see if you can blow air into it to see if its clogged. Sometimes it just gets clogged with dirt and dust. If the tube is clogged, and you cannot blow air through it, then see if you can get a small somewhat flexible wire and push it through the tube.
Hopefully it will make it all the way to the other side.
Hope this helps.
Good luck.
Mac =)
Posted on Feb 11, 2008
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
MNTECH
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
SOURCE: Water inside my Hotpoint Fridge/Freezer RFA70
There is a kit available, WR2X9393 which includes an aluminm heat probe which you attach to the heater to prevent icing of the drain
Posted on Mar 06, 2009
Hi there water building up and flooding back from my fridge drain hole.hotpoint model number rfa07
clean ice from drain hole then take a wire hanger and cut it to about 3-4 inches , wrap one end around defrost element anf the other end down the drain hole . use a turkey baster to force VERY hot water down drain hole to clear build up and debris
Feb 24, 2013 | Hotpoint RFA60 Bottom Freezer Refrigerator
Water from fridge not going down plug hole into container. How ofter should the water container be emptied at the back of the fridge/freezer I have a sub zero frigerator #550 its about 15 years old....
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. .
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.You can use a hair dryer and remove the ice buildup
Oct 30, 2008 | Refrigerators
There was standing water in the bottom of my Roper refrigerator under the crisper drawers. The drain pan under the fridge was dry. I cleaned up the water and vaccumed under the bottom of the fridge. ...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Jul 31, 2011 | Refrigerators
Hello I have Had my side by side for 5 years now Model # MSD2351KES. Sometime during the night I guess it stopped working and is not getting cold. What could it be? or is it just time for a new one?
Is the freezer still freezing even though the fridge is warm? if so yayyyyy! siimple fix.... hopefully!
Refrigeration systems are designed to last forever as they are hermetically sealed so your first place of interest will be to first let the fridge sit for a day to possibly defrost. Let me explain. There is a little drain from your freezer to your drain/evaporation pan in the base of your fridge that carries water resulting from the defrost cycle. If this drain which is the size of a large drinking straw, becomes plugged, the water will build up, freeze and block the flow of air from the freezer to the fridge thus resulting in a warm fridge.You just have to find and unplug the line.
Now... IF the freezer is not freezing then you probably just need a new defrost timer. This timer is necessary to clear the system of ice on a regular basis and when it is time to replace it it will stick on defrost. Defrost timer is located under the fridge and should be readily accessed. and adjustable. try to turn the defrost dial adjustment and the fridge should start again... if it does you will still need to replace it but now you can do it yourself without the service charges and possible dishonest opinion of " You need a new fridge!" Hope I helped!
Jul 18, 2011 | Refrigerators
Water is appearing under the front left foot (as you look at it). It builds up in to puddle over night. I have checked the instructions which are difficult to follow (not very clear English) but it said...
Freezer drain is plugged.
Two solutions:
1. Call a service repair company.
2. Turn off both controls (turn to lowest setting) and open freezer door for minimum of 24 hours (max 48 hours). That will thaw drain sufficiently.
What has happened: Somehow the freezer drain had ice build-up and eventually froze solid. Every time the unit went into defrost mode, the melted frost (now water) had no place to go. The normal exit is the freezer drain hole which leads to the drip pan underneath. That exit is plugged with ice, so the water went where it could - across the freezer floor and out the bottom of the freezer door. You found it and wondered why.
Mar 20, 2011 | AEG S75348KG Bottom Freezer Refrigerator
I have a GE PTC22 fridge. I'm getting ice building in the freezer drain pan causing the evap fan to stop and things to get warm. I've cleared the 2 drains at the back left of the freezer, and is I see a...
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | GE PTC22MFM Top Freezer Refrigerator
My 20+ year old top freezer fridge sometimes leaks water from the freezer into the fridge through the air vents. Is this from the defrosting of the freezer and how do it get it to stop?
You will need to take the freezer compartment apart. Remove the ice build up. Clear the defrost drain located under the coils near the center of the drain pan. Usally some very hot water will work in clearing the drain. Once it is clear and the ice is all removed from the bottom of the freezer you will need to check and or replace the defrost bi-metal and the defrost timer. The bi-metal is located on the coils in the freezer. It looks like a little can with two wires going to it. The defrost timer depending on the brand can be located in the refrigerator near the controls,or under the refrigerator behind the kick plate. Or in the back of the refrigerator near the compressor
Oct 14, 2009 | Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
I have a Bosch fridge freezer. There is a constant water build-up on the fridge floor. Sometimes the water escapes from the fridge onto the kitchen floor. Cleaning and defrosting, recently carried out,...
hi thanks for the question the drain from the freezer to the drain pan is clogged up now with these new fridges the drain hose goes between the outside and inside wall of the fridge so the only way to clear the drain is to shut the fridge down with the doors open to allow the ice to thaw buy yourself a small plastic hose from hardware store and after it has thawed go to the drain tube at the back near the drain tray and blow into the tube to clear this should solve your problem thanks the appliance doc
Sep 22, 2008 | Refrigerators
WATER pooling in bottom of fridge
did you try to remove the 2 ***** in freezer floor???. if not remove the floor and check for ice build up underthere, if so:
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 12, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
Refrigerators Logo
54 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
