Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I need a wiring diagram for a Craftsman model 139.53990 3/4 hp garage door opener. Can't get it from Sears.
I took it apart to replace the gears. Several wires came off unintentionally. Should have tagged the other wires but didn't. The wires in question are those on the two run capacitors and the motor itself.
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
  • 118 Answers
SOURCE: motor runs but door does not open
you have a stripped gear on your opener. Replace gear and sprocket kit
Posted on Feb 08, 2009
SOURCE: Sear 1/2 HP Garage door opener with replaced gears
The actual problem is after power on the opener, its initial state is uncertain. It may be in ready to close or ready to open state.
If the garage door is in closed position, likely the opener will still try to close it, because its initial state is uncertain. That's why you guys see it travels 2 seconds and reverse.
In order to fix this problem, after you power on the opener, do NOT hook up the chain, and do NOT mount the sprocket cap(so you can see the sprocket travel direction). While you watch carefully at the sprocket, press trigger button on remote control or ask someone press wall control button. Make sure the sprocket turns clockwise and stop. If the sprocket turns counterclockwise, press the control button again, so it will turn clockwise. Let it finish clockwise turn. At this moment, the opener is in ready to open state.
Cover sprocket cap and hook up chain. Mount door bracket and adjust. Your door must be in close position.
You are ready to go.
Posted on Mar 07, 2009
SOURCE: How to reprogram Sears Mult-Function Keyless Entry garage opener
On the garage opener that actually opens the door the one on the ceilling has a green or orange button that is called the learn button just press and release it you have 30 seconds to punch in a 4 digit code and when your done press and hold the enter button until the lights on the garage open blink once or twice then just press the code again and it will open the door press enter once to reverse the effect and and twice to stop the door completely.
Hope that helps
Posted on Mar 17, 2009
  • 10865 Answers
SOURCE: need part 41A2817 drive/worm gear kit for Sears
as long as the door is less than ten years old, sears will stock the part you need. you can contact them through this link.
http://www.searspartsdirect.com/partsdirect/index.action?psid=58709328&sid=PSx20071217x00001a
Posted on Apr 22, 2009
I need awiring diagram 3/4 hp craftsman garage door opener
Wiring diagrams have never been available. What is your problem?
Nov 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need the instruction to replace the gear on the garageopener
i figured it out by just taking it apart trial and error. Thanks anyway
Jan 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Motor will not stop.
The wiring for the limit switch assembly is:
Yellow wire to the up limit contact
Gray wire to the center contact
Brown wire to the down limit contact
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nylon gear replacement for automatic garage door
If you buy the gear kit it comes with a set of instructions. The part number is 41A2817.
Oct 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp opener clicks and grinds but doesn't work
I had a similar problem with a Craftsman opener. There are 2 gears that are in the housing, these are made of nylon/plastic and are built to wear out over time. My model was 139.53664SRT , the gear kit is 41A2817 and you can order the entire thing from Sears.com. If you get the housing off you can see if you just need one of the gears, either the drive gear or worm gear , you can order those off of ebay pretty cheaply. You'll need screwdrivers and probably some wrenches to get things apart and install the new gears, you'll also need to use lithium grease on the gears, that keeps the gears from eating each other up too quickly.
May 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need part 41A2817 drive/worm gear kit for Sears
Apr 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't move
goto http://www.garagedooropenerguide.com/installationmanuals.html
download the pdf for the unit that is closest to what you have, go thru the diagnostics.
Hope this helps
Mar 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
128 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
