Question about Lucent Lands Phones
We use an old Lucent 18d phone. How do I change direct extension menu options?
I somehow managed to change one of the settings on our phone recording. Originally, when a person called in, they could choose an extension and were transferred to that person's voicemail. Now, when they choose a particular extension, instead of getting that person's voicemail, the phone puts the caller back to the #10 voicemail. This all occurred when I was trying to record a second message on our phone system, wherein a caller could choose "for our hours choose 2" kind of thing. Now there is a very old message that says it is selector code 2 announcement 1.
  • Paul C. May 02, 2017
    It sounds like the voicemail selector codes were changed. What is selector code 1 currently set up as?
  • 537 Answers
SOURCE: Changing MAIN voicemail announcement
I am not a phone installer and we have another vendors' phone system here at our work.
It can be *extremely* difficult setting up these phone systems, even with a manual.
Here is one such link that might help:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Here is another forum that has lots of friendly folks that might be able to help
http://www.sundance-communications.com/forum/ultimatebb.php?/ubb/forum/f/8.html
You will get an answer much sooner on there than here probably.
Mike
Posted on Nov 09, 2007
SOURCE: Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Posted on Aug 27, 2008
SOURCE: Voicemail won't allow recording transfers back to receptionist!
Are the mailboxes set up?? What happens is a call goes to an extension, there is one program set to tell the system that if a call rings 4 times, go here(voicemail). Once it goes there, the voicemail system sees that there is or is not a mailbox matching that extension. If there is, the call goes to voicemail, if not, it transfers to the operator.
OR.....Does your system display the correct time? Its possible that the phone system lost its programming, and doesnt know where the voicemail is.
Both might need a professional tech on site...a bit too hard to help over a forum.
Posted on Mar 20, 2009
ynotphone
  • 192 Answers
SOURCE: Directory Access Changes
Changing CCR tree...
Ok, for the first part:
Changing the Greeting in the Auto Attendant via CCR tree... you have to get into the ADMIN mailbox:
-> FEATURE 9 8 3
-> Password 1020000 for 3 digit extensions -or- 120000 for 2 digit extensions
(these are the default password, but can be changed)
-> OTHR
-> CCR
-> ADMIN
-> TREE 1 and press OK
-> CHNG
-> Path 0
-> REC then press PLAY to listen to the greeting, and ensure that is the one that you need to change
-> REC the new message
-> remember to SAVE! otherwise all is for not.
THIS MAY BE REQUIRED FOR OTHER TREES ex 2 or 3, listen too all trees and change if required... same steps to get into the trees and prompts.
Ok, second part:
To change the locations of where Press 1 goes do that same steps as above, but Path 1 is for number 1...
Path 2 is for the number 2... so on and so forth.
Posted on Apr 27, 2009
tanika-15
SOURCE: NEC Phone System - Setting Up Operator's Voicemail
i need u to help me set up the vmail on my phone
Posted on Jul 29, 2009
How do I change the time on my Lucent Partner 18d
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
Mar 30, 2010 | Lucent PARTNER18 Corded Phone
Hi I have a Lucent Partner 18D phone. I can't
Intercom 777
enter admin extension (0)
enter password (1234)
Option 3
Jul 28, 2009 | Lucent PARTNER18 Corded Phone
How do I retrieve my messages on the Lucent 18D
Hello.
To listen to your messages
Press Intercom 777
At the prompt enter your extension number (Feature 00 before starting the procedure will tell you your extension number)
At the prompt enter your passworde (1234 is the default)
Listen for the instructions
Cheers
Jul 07, 2009 | Audiovox Corded Phone
Cannot change outgoing message on Lucent Partner 18D phone system
For an extension of the Main Automated Attendant greeting when callers call in.
Which voicemail do you have? You indicated the phone model, but not the voicemail model.
Jun 16, 2009 | Avaya Lucent Partner 616 Phone
How do you reset clocks on Lucent Partner 18D phones?
AT EXTENSION 10 OR 11:
FEATURE 00
LEFT INTERCOM TWICE
#103
ENTER TIME AS 4 DIGITS, 24 HOUR MILITARY FORMAT
FEATURE 00
Aug 14, 2008 | Lucent PARTNER18 Corded Phone
PARTNER - 18D
Login to admin mailbox
ext 0 or 99
listen to menu
Jul 31, 2008 | Lucent PARTNER18 Corded Phone
Change te number of rings
I need to change how many rings it takes my system to answer . It is set for attendant , I need it to answer after 5 rings . I need this changed because I now have a answering service that is set up though my phone provider verizon to call forward after 4 rings Lucent partner 18d
Jul 18, 2008 | Lucent PARTNER18 Corded Phone
Lost my owners manual
Press "feature" 0 0 next press the left intercom button 2 times then press #103 (do this from extension 10 or 11)
enter the new time in 24 hour notation....ie 2:15 would be 1415 then exit programming by pressing "feature" 0 0 again.
Hope this helps.
Mar 17, 2008 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
67 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
