Next question, how do I get the slime out of the clothes from washer?
My washer is leaking slime onto my clothes. I have scrubber rubber with vinegar, let it dry, scrubbed again, then wiped clean with paper towels. I then ran a load with 2 cups of bleach. My delicates got slime from front load washer. How do I get this out???
  • 4,128 Answers
Cleaning the rubber door gasket will not get rid of the slime issue. The slime comes from buildup on the outside of the washer drum. There are two causes for this. First, if you always close the washer door after use, then the moisture inside the drum cannot dissipate and the slime can form. Also, using the wrong type of detergent (or an excessive amount of the correct detergent) can cause the slime. There are front load washer cleaning products that you can purchase and run to clean the slime from the outside of the drum.
Posted on Dec 16, 2014
Wire came out of front plastic gray circular piece and washer leaked water everywhere
Sounds like some article of clothing got between the door glass and door boot and pulled the rubber door boot away from the front of the washer. Check and make sure the rubber boot is not torn. If it is ok you should be able to slip the lip of the door boot back onto the front of the washer, make sure you get it in the grove. Then put the wire retainer back around the boot, you may need an extra hand or two to hold it and stretch the spring back on. Hope this helps
Sep 02, 2011 | Kenmore HE2 Plus Front Load Washer
How do i clean the rubber around the door as it has all black slime and it is getting onto the clothes
Best way is to use a washing machine cleaner called Affresh, it can be purchased at any grocery store on the laundry detergent isle.
Please rate my solution if it was helpful to you.
Thanks, Repairman45
Dec 19, 2010 | Electrolux Washing Machines
Water leaks past the water pump filter gasket reseating the filter does not stop the leaking lg tromm Front Loading Washer
I regularly clean my filter of slime and debris (after not even realizing this needed to be done and having my pump give out of me). TWICE I have awoken to a flooded basement due to leaks in the filter area:
The first time, the plastic stopper was not in the small rubber drain hose properly and had popped off.
The second time, I had cleaned the gasket, inserted it tightly like I always do, and awoke to another flood! I thought perhaps the rubber gasket on the filter was on wrong, but it was fine. I inserted it tightly several times and water still poured out! It turns out there was a small stone lodged in the thread of the receiving end of the filter causing there to be a bad seal. Lesson learned. Another $2000.00 worth of flooring ruined.
May 15, 2010 | LG WM-1832C Front Load Washer
Bad smell when starting a new load the next day
These are some good tips. However, leaving the door open between loads decreases odor by drying out the residue which can make the residue difficult to remove. Also, the residue will affect the next wash load.
The only way to have a truly clean washer is to remove the odor-causing residue. The "splash area" just 3-5 inches above the normal waterline is where the worst buildup is. To clean the whole tub use a washer cleaner that is able to be used with clothing in the washer. The added laundry will raise the water level to include the splash area.
There are many washer cleaners on the market. Some are all natural and can be used with laundry to safely clean inside the washing machine. After you get rid of odor you'll need to change your washing habits so it doesn't come back.
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher is leaking in front onto floor. Water level during washing seems too high. Float is not obstructed by any object. What can I do next?
if it seems to be coming from the front it may be the rubber door seal they are not to expensive and not very hard to change if it is leaking under machine it may be the seal that sits on top of motor if water is leaking around motor the seal in the bottom of the washer is damaged
Dec 17, 2009 | Washing Machines
SLIME AND MOLD BUILD UP IN WASHER WITH A BAD ODOR, HOW DO I REMEDY THIS?
hello mam
please clean the washer by a descaling powder without loading clothes .and then check the odor
Oct 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
My washer keeps leaking grease onto my clothes!
the problem that you have is the bearings have badly worn,a lot of companys will just replace the entire drum rather than mess about with the bearings as this does not always solve the problem.sorry to give this bad news.
Jul 15, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Leaks water onto floor while in use
It sounds like a water hose is leaking or has a split in it. Check the water in-take hoses on the back of the washing macine, to see if its leaking or split. If they are leaking, unscrew the hose and check or replace the rubber washer, thats in the brass screw-in part. Next, unplug the washer power cord, unscrew the intake water hoses that are in the back and turn the washer on it's side and check the water hoses underneath the washer. They may be loose or split. Any hardware store should have these hoses in stock, like Lowes or Home Dept, or your local "Do it center".
Jan 19, 2009 | Washing Machines
WMA 10 Hotpoint firsy edition
elbow grease will sort the problem take plastic clip off and take metal ring off pull most of rubber free the problem is grease ,petrol, etc on clothes that soaks into rubber start by scrubbing .with power off obviously its an easy job
Sep 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
