Question about Homelite Garden
When my homelite 3316C gets hot it stops running. What part do I need to fix this problem?
Nothing
  • Homelite Master
  • 1,169 Answers
First make sure cylinder fins are free of debris; otherwords, good air flow around the cylinder.
Second try another known good plug. Plugs can fail when hot.
Third check for spark when it dies, If none present at this time then the ignition coil is failing.
Posted on Dec 16, 2014
2 Suggested Answers
emissionwiz
  • 76848 Answers
SOURCE: homelite gas chain saw 3316C How do
Lossen the bar and pull it out to adjust the chain tension
Posted on Jun 16, 2011
My homelite 3316c chainsaw it seems the idle is off when i start it it runs full throtle
I would think that either throttle is hung open where the choke mechanism didn't release it or the throttle butterfly is missing.
Nov 15, 2014 | Garden
I have a homelite 3316c when it starts up it goes full throtle it doesnt idle right is there a idle screw
There's a low speed screw and a high speed screw. There is also a tickover/idle screw. Its possible this is just screwed in too far. The high and low screws may have tamper proof covers on for emissions regs. Remove the top cover and you should see the screws on the side of the carb. H&L are side by side, idle is on the linkage to throttle trigger.
Homelite chain saw 3316c
ok check the magneto if rusty clean with fine grit paper then try it if not then may be time to change the coil and magneto..
Jul 13, 2014 | Garden
I have a Homelite UT 10520. It is a refurbished chainsaw. It has ru about 30min. It is running hot. My mixtture is 50:1 and my gas is 90 oct. I think it is running lean. It will not get to the max...
lI thinkthe oil to gas is too rich with Gasoline. My book says 40 to 1. Not enough oil will cause it to run hot and burn or stick. Also some of the later models take the synthetic oil andif you use the outboard or other oil it will run hot and ruin the saw.
Jul 07, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
I was using my Homelite 330 and it quit running.Now when it starts it runs at a high rpm for 5 seconds or so then winds down and stops running. I've checked fuel. The local repair shop won't even...
dO  tune -up.Here is a link : www.ehow.com/how_6971799_homelite-chainsaw-tuneup-instructions.html also visit www.homelite.com/ for more.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 07, 2011 | Homelite ZR10926 16 Chain Saw
Homelite gas chain saw 3316C How do I tighten the chain?
Jun 16, 2011 | Homelite Garden
I ;have on older homelite super 2 saw. can use the newer oil in this saw with the 50to 1 ratio?
There is no reason why you cannot run any two stroke on todays two stroke oils ( its not like four stroke engines where you use different oils dependent on the age ) however i am not sure i would run it at 50-1 i would be more inclined to run it at 25-1 as it is an old engine.
Jan 29, 2011 | Homelite Garden
I have a homelite yardvark blower and I want to change the fuel filter. How do I change the fuel filter? Yardvark runs fine at beginning, but begins to run eradicatly after a short time. What's the...
could be fuel lines, fuel filter, or your carburetor needs to be rebuilt. The carb has thin rubber diaphragms that get hard over time, hot weather, or stale gas. Need more assistance,
email desertairrepair@aol.com.
Jan 31, 2010 | Homelite 'Yard Broom' Leaf Blower
Runs well untill it gets hot. then cuts out
If it's the little xl model, it's probably the ignition coil breaking down when it gets hot and therefore it can't and won't be able to handle a load. Also, scarred pistons skirt or rings could also be some of the problem here. Make sure your mix for a Homelite saw is 40:1 not 50:1 like most saws are. Homelite seems to run better with a heavier oil mixture. Good luck.
Aug 02, 2009 | Garden
Garden Logo
71 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
