Question about John Deere Garden
How to check problem with john deere 200d lc cooling motor stoped moving
Dis asm fan motor and ck variable fan soleniod
  • John Deere Master
  • 2,760 Answers
If i understand you right your saying the cooling fan doesnt work at all , yes it's run by a electric motor , it's triggered by the ECM via a control relay /fuse that gets a cool /notcool signal from engine coolant sensor any of these not working correct will produce the effect u see, normaly this will make the fan ,Modulate (off/on) for diff enviroments like mine doesnt even run when plowing snow but runs all the time plowing a field , due to diff time of year
Posted on Jan 07, 2015
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
JOHN DEERE L130 SPARK PLUGS ARE NOT FIRING
first i thought this engine had only one spark plug ?? second it's a kohler engine right ? this model has a coil (thing that makes fire for plug) that sits right on top of engine under cover this allows grass and other stuff to get inside it and cause things to overheat a bit this makes coil go out when things get hot in there but it usually will restart when it cools off after a few hours your gonna need to remove cover replace overheated coil and clean this entire area with compressed air to get things cooling again , ck out youtube for some of my easy dissassembly videos of this motor (kohler coil change)
May 31, 2014 | John Deere L100 Series
John deere 214 garden tractor drive train not moving the tractor
a 214 an oldie but a goodie ck your drive belt i'll bet it's broken tough to see i know with mower deck on but you might get a glimpse of it thru front looking in
Nov 12, 2013 | John Deere &Reg Branded 27" Tractor Metal...
Front lights stoped working in my john deere 6510 the fuses are fine
well if your sure it's not the fuses or bulbs ck the wire connector on back of lights as it snakes around the side of radator i've seen em come apart from the vibration before right as it goes into wire harness
Nov 11, 2013 | Garden
I have a L118 John Deere mower. When cold, the mower moves forward and reverse without problems. I mow my 1/2 acre yard and at the last couple passes, the mower barely moves forward and has no reverse. ...
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
May 23, 2011 | John Deere Garden
My johnb deere L120 engine runs fine, but after about 20 minutes the tractor slowly stops moving, i dont know if this is a drive belt problem or something wrong with the hydrostatic?
Hi, most likely the hydrostatic is over heating. Remove the battery and battery carrier. From here clean any grass and debris from the hydro and cooling fins, also check the cooling fan condition. Under the mower check the idler pulley on the hydro drive belt is travelling freely. Hope this helps, regards Phil.
May 08, 2011 | John Deere Garden
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Sep 08, 2010 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Have a 19 hp john deere zero turn riding mower. starts up, blades turn, has oil. will not move forward or backward. does the hydrolic oil level have anything to do with that?
ck on traction motors for lever or nut to release fluid. Can you move mower with engine off?
If so, this is your what is wrong traction motors
are disengage
Aug 30, 2009 | Garden
John deere lt120 , 2004
My bet would be a saftey switch. On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. If there is a handle that engages and disengages them, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse.
Hope some of this helps.
C
Sep 27, 2008 | Husqvarna Zero Turn Mower Z5426
Garden Logo
102 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
