Question about Furniture
I have a Amanti de vino Wine Cooler model PFWC18 and need to replace the top compartment fan model HSO9025 - 12 volt dc. Where can I find this part? Thanks.
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
SOURCE: Magic Chef MCWC44DZ E4 error
I found the connectors corroded for both fans. The lower fan connector had one pin that was completely destroyed. I hard wired the wires together as a test and the unit is working perfect. Check the fan connectors by removing the two screws that hold the shelf in place and cafefully slide out fron the cooler. You will have to disconnect several connectors hidden in the right side of the shelf before you can completely remove it. Good Luck.
Posted on Oct 18, 2009
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
  • 47 Answers
SOURCE: E3 error code on my Magic Chef Wine Cooler - what
could be a broken fan, compressor gone, thermostat. neither one you can fix. you need a refrigeration mechanic or a new fridge
Posted on Nov 11, 2009
Amanti de Vino pf-wc18. where can I get a fan?
http://us.wow.com/search?s_pt=aolsem&s_it=aolsem&s_chn=14&q=wine%20cooler%20parts
here is a list of options. Remember to check with BBB (independently not through some site link). before sending payment or using credit card with unknown websites.
Nov 29, 2015 | Furniture
The fans in my cooler stopped working. how can I fix, or replace them ? I have an DCW283BLS Model
There are 3 fans in this unit. One high up in the back panel for defrost (which should seldom run), and two inside the box with the LED's that divide the compartment into upper and lower areas. All are interchangeable. Replacement parts are available through Sears Parts Direct.
If you intend to do the repairs yourself, make sure the cooler is unplugged when working on it. To gain access to the two fans in the divider box, remove the wine racks to give you more room, and just remove the four screws holding the top of the divider box on and lift it off. One of the fans is directly behind the PC board and the other is inside the 8x10 foam box to the rear of it. Be careful with this foam box, it is delicate. To gain access to the fan inside, use a thin bladed knife or razor blade to delicately separate the top from the sides.
Before replacing fans, try tracing the leads from the fans to the PC board and swapping the plugs for the fans on the PC board and plugging the cooler back in to see if any of the fans are working. Make sure you restore the plugs to their original positions. If all three fans are not working, the problem may be the PC board or the thermocouples.
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
One side of my Eurocave SoWine Cooler does not work.
As you must be aware there are individual fans in both the compartments. Check if the fan is running in the compartment not cooling. If not, check the wires / connection of fan or replace the fan.
If the fan is working than the issue may be with the THERMO ELECTRIC ELEMENT. you'll need to replace it.
Sep 09, 2013 | The Wine Enthusiast Wine Enthusiast...
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Top fan is not working
The HVTS18DABB wine chiller is truely a piece of **** when it comes to their fans. I have had top fans in the top chiller fail. Solution: Don't buy the replacement part as it will only fail again. Instead, go to your local computer parts store and purchase a high quality 120mm computer fan with a good motor and bearings. On the old fan, snip the wire harness as close as possible to the fan body. On the new fan, remove the connectors that come on the fan. Attach the red wires and the black wire and wrap each with electrical tape. Trim back the yellow wire and tape the end, isn't needed. Remount the fan and you are good to go. i plan on replacing the bottom fan soon with a quality PC fan as well.
Feb 19, 2011 | Haier HVTS18DABB Wine Cooler
Need to replace the fan in the upper compartment. Do I access it from inside or from the back? If from the back, do i just pry the back off? Then how is it resealed?
you must try from insyde, all my model's have acces from inside. you dont have a seal, remove carrefuly to not bent somethig and it will be ok. I presume that fan is an tangetial fan (that kind of fan have all my wine cooler's) you will need a screwdriver phillips and maybe a wrench.
Feb 21, 2010 | Danby DWC283BLS Wine Cooler
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Furniture Logo
285 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
