hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this at reliable-store
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
po768 is shift solenoid "d" control wire open or shorted. p0700 is a generic code that the transmission send to the ecm and is not relivant at all. to fix the first code p0768 you will need to know if the wire is broken or damaged from the solenoid to the computer the solenoid is inside the transmission and the computer is under the dash board infront of the steering wheel. here is the procedure you need to take to diagnose it.
Jun 7, 2015 - Radio volume control on 2008 Subaru Tribeca does not work, but remote volume control on steering wheel works. ... does not... Replace the volume control(rheostat) inside the radio. .... Oct 09, 2014 ' 2007 Subaru B9 Tribeca.
most likely cause is a bad transmission fluid pressure sensor this sensor will set both codes. have someone with a scanner rad the info from the sensor it is most likely open or shorted...best guess replace the sensor.
