2005 Nissan Almera 1.6 Logo
J
Jane Wright Posted on Dec 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My speedo has stopped working i had the speed sensor replaced it worked for just 1/2 mile n stopped, local garage said new gearbox does this sound right to u guys
David Harrelson
Level 3:
  • Nissan Master 5,456 Answers
  • Posted on Dec 18, 2014
David Harrelson
Nissan Master
Level 3:
Answers
5456
Questions
17
Helped
1101725
Points
15442
If they mean the speedo gearbox, maybe. I think this works like older cars in which you have a gear on the transmission shaft which drives a gear on the speed sensor, and sometimes the gear on the transmission shaft can break the clip which locates it and it slips out of position. Many transmissions allow removal of back section to gain access to repair this. However, some newer cars have a speed sensor which uses an electromagnet to pick up signal from a internal magnet. Removing the speed sensor from the transmission (easy!) should help determine the cause of your problem.
2 Related Answers
Anonymous
  • 314 Answers
  • Posted on Jun 12, 2009
SOURCE: 04 Maxima abs light and brake light on
The first step in diagnosing this problem is to hook it up to an ABS scan tool and see what trouble codes it has put out.
Anonymous
  • 2187 Answers
  • Posted on Mar 17, 2010
SOURCE: speedo does not work, replaced the speed sensor
You will have to inspect the speedo cable that goes from the back of the meter through the car's firewall and unto the transmission. There could be a break between the transmission and the firewall or at the back of the dashboard.
1984 Porsche 944 Speedo Cable
might be the sensor on the gearbox that is faulty or wire is damaged and going to earth.
1helpful
1994 chev 4x44l60 trans,np241c tcase,speedo stopped working trans immedeatly stopped shifting past 2 gear
FIX SPEEDO MAY NEED A SPEED SENSOR AND IT WILL NOT SHIFT IF IT DOES NOT SEE THE OUT PUT SPEED
4helpful
Speedo not working , vw golf 2001 .
I tell you for sure that is the sensor problem from gearbox.the sensor, or the wire. The fuel gauge is connected to the gearbox because is not very nice to corner and the fuel gauge go up and down. Now because the fuel gauge "didn't know" how many miles did you made, he is moving up and down. All recent cars have the same problem, and had the same problem on my girlfriend Golf 4. It was the wire. The mecanic forgot to put it back.
1helpful
The speedo on my 98 1.8 i six speed mx5 sometimes
Change speedo sensor located on a gearbox-if electric.If wire-check wire and dashboard instrument panel
Speedo stopped working. Have an audi 90 done 255,000 miles oops
need to check speedo sensor or drive gear in gearbox is connected,may have been disconnected after work was done,or the sensor has packed up,unlikley to be speedo itself if its been ok in the past
3helpful
2answers
Ford focus speedometer stops working intermittently and for various amounts of time if it does not start again The mileometer and tripometer numbers turn to dashes
I have the exact same problem, turns out it’s down to a faulty speed sensor, common problem apparently. Follow this link for more info. Speed sensor
1helpful
1helpful
Speedo dial dnt wrk and car jus cut off whilts driving
very common fault with speed sensor in gearbox. fairly easy fix though some seize in which can be annying. tell a garage you want a new speedo switch should be bout £100 needs to go on a ramp for removal of sensor you need a new one 100 % Thanks Davelee
No gear at all
take ur gear box of and chech wear ur speedo plug is and if ur car run before ur plug got lost then yh thats ur proplem
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
