Question about Tilia Foodsaver V835 Vacuum Sealer
What kind of glue should I use to re glue the black strip on the bottom of the sealer?
Sorry, I was asking about a foodsaver.
3 Suggested Answers
  • 88 Answers
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Foodsaver troubleshooting
The same thing happened to mine and I found a really,really inexpensive way to resolve it. I don't use original foodsaver bags and I found out that their thickness might not be detected correctly so it won't vacuum. To compensate for this, I used an ordinary piece of notebook paper. I cut it to a size of 4 1/2" by 1 1/2". I set the long side in the middle of the liquid catching tray and let it lean back towards the heat strip. Make sure it doesn't cover the heat strip or it won't seal. Now I inserted the bag as the directions say, close and lock the top, and it vacuums and seals perfectly. b40a3e78-1fd3-4c38-9291-c5c4e3885648.jpg
Jan 05, 2014 | Kitchen Appliances - Others
Vacum works heatseal does not seal can i replace seal
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver pro locked up. 3 green lites blink off and on. is the problem fixable?
The reset button is the small black rubber covered hole on the left side of the vacuum channel. If you press down on that with something like a knitting needle with the unit on, it should reset
Oct 17, 2010 | Tilia FoodSaver V2240
Foodsaver vac800 not sealing bags any way to fix heat strip?
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Sep 16, 2010 | Tilia Foodsaver V835 Vacuum Sealer
My food saverf V 835 just stopped sealing. I haven't used it that much, and it worked fine last time I used it.
I just spoke to customer service. I was told there is no replacement part for the heating element. They did offer me a discount on a new Foodsaver.
Feb 21, 2010 | Tilia Foodsaver V835 Vacuum Sealer
My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Aug 22, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver compact vac 550 sealing strip doesn't seal
My machine stopped working because the sealing ribbon was broken and the tape was worn. FoodSaver no longer does repairs. I knew the wire was called nichcome ribbon so I searched that. I checked the resistance of the ribbon on my machine, it was about 3.8 ohms. I found a site called mpakonline.com and from their site I bought 1/16 x .005 nichrome ribbon and 3/8 x 5 MIL. x 18 YD Acrylic Teflon Tape. The total cost of these items was about $36.00, the ohm value of their ribbon was 1.66 somewhat less.I used ends from radio shack made the repair and it has been working fine for the last two months and I have enough material leftover for about ten more repairs.
Nov 14, 2008 | Heating & Cooling
Tilia Foodsaver V835 Vacuum Sealer Logo
127 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Bonard Allen
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
