Question about Ricoh Office Equipment & Supplies
How do I enter Service Mode on a Ricoh C900 printer? I'm showing SC241, but can't find it in the service manual... does anyone know what problem that is referencing? Can it be cleared in Service Mode
I have tried Clear Modes / 1 / 0 / 7 / Clear / Stop, but I think that's out of sequence. I can't find the solution in any of the Tech Manuals I have. When we reconnected the unit to show a potential buyer, we had two wires reversed on the box on the back, where the rip is located. The LCD screen was black until we switched the wires (The IKON tech had these marked 41b and 41c, but it's actually 416 and 415). When we flopped the wires, the screen worked, but it threw this code. Any ideas, please? Thanks!!
blueydfox
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
  • 68 Answers
SOURCE: How to enter ''service mode'' on Aficio SP C221SF Color MFP
this is priveledged information and kept away from non service personnel to protect both you and the device from unqualified access and possible damage.
if you have an issue that requires entering service mode please call for a ricoh tech this ensures that you are protecting the investment you have made in purchasing a ricoh device.
Posted on Sep 16, 2009
  • 9 Answers
SOURCE: HP service codes to unlock tech mode
http://www.printertechs.com/tech/pin-servicemenu.php
Posted on Nov 12, 2009
SOURCE: Unable to enter program mode for Sharp AR-C260M Copier / Printer
Solved the problem by switch on press #P Then * then C then *  then 14  This will then ask if to execute the action to clear the service code H5-01.
Will need to ensure that the fuser unit is not causing a blockage on the feed out path as this code is caused by 5 errors / misfeeds in the Fuser unit.
Posted on Nov 16, 2009
SOURCE: I need to know how to enter the service mode on a Ricoh CL7000
i need to fix a sc 827 code on a ricoh mp 5500
Posted on Feb 09, 2010
Model W240. How can I enter service mode?
enter service mode Mohammad, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Entering Service Mode HP LaserJets
canonipf Service Mode
Service Manual free download schematics datasheets eeprom bins pcb repair...
Ricoh 6000 service mode
Apr 11, 2016 | Ricoh Office Equipment & Supplies
How enter service menu in ricoh aficio fx16
Press the following buttons into the next order :
press MENU, then press # , then press 1-9-3-4
The LCD screen will show TECH .
Now you are in service mode.
For to change the " Dial Mode " after entering into " TECH " Mode you will need to enter " Data Setup " and then " Dial Mode " and the you can change it from " PULSE " into " TONE " mode.
Do this procedure to go back to user mode :
Press MENU , then press # , then press 1-9-3-4
Oct 16, 2013 | Ricoh Aficio Office Equipment & Supplies
How to enter service mode for ricoh mpc 3003sp
YOU NEED TO PRESS C BUTTON(RED) LATER PRESS KEY 1 , KEY 0 , KEY 7 & HOLD THE YELLOW KEY FOR SEVERAL SECONDS, THEN THE MACHINE WILL ENTER SP MODE
Sep 23, 2013 | Ricoh Aficio AP3800C Laser Printer
How to enter SP Mode for Ricoh Aficio sp 3200sf
"Menu" ? "#" ? "1" ? "9" ? "3" ? "4" ? "Menu"
The display shows "Tech Mode> Tech menu"
Press "OK" to enter Tech menu.
Jun 06, 2012 | Ricoh Aficio SP 3200SF Multifunction...
My spare Ricoh AP3800c has decided to show a SC541 warning, I understand that has to be reset in 'Service Mode' is it possible/safe to do this myself? if so can anyone give me an idiots guide to doing it?...
Power off the printer, wait a while and power on back, while the printer is loading, unplug the printer from the AC power source and wait for some minutes before you plug in back and power on. This should reset your Ricoh AP3800c printer. if problem persist, follow the below procedure.
Hold down the two arrow keys and count to 5, hit the enter key, the machine should be in service mode if nor repeat. use arrow key and scroll to machine press enter scroll to data log press enter scroll to pm counter reset press enter, scroll to fuser oil press enter and execute this mod Please. DO NOT GO INTO ANY THING ELSE or you could do serious damage to your machine!! If your machine has a Copy feature expander you must press Clear mode, Press 1-0-7 and then hold down the stop cancel key 4sec. go into copy mode press 7-804-809 press execute button again Please DO NOT GO ANY WHERE ELSE as damage can be done to your machine.
Take care.
Jul 20, 2010 | Office Equipment & Supplies
I've lost the user code for a Ricoh Rex Rotary MP C3000 colour photocopier and can't use it. Does anyone know a master or engineer's code or smilar so I can get in and reset it?
you enter service mode..and you search cancel the pasword.
Entering and Exiting SP mode 1. Press the Clear Mode key.(reset button it should be yellow) 2. Use the keypad to enter “107”. 3. Hold down Clear/Stop for at least 3 seconds. 4. Enter the Service Mode.
Jun 12, 2010 | Ricoh Office Equipment & Supplies
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
2. Use the keypad to enter .107..
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
My ricoh 1022 after puting power on it shows error code sc542
What code? Try entering service mode then turn off copier and turn it back on. (push these buttons in sequence Clear modes (yellow) 1 0 7 then hold the red stop button for 5 or so seconds you are now in test mode
Jun 10, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
83 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
