Question about Bosch Washing Machines
I get err01 which I think is related to the door interlock ,is this a matter of replacing the door interlock or something else
Removing interlock and checking mechanical parts
  • Bosch Master
  • 2,333 Answers
The code is for a door lock issue,it means the door isn't closing properly,most likely it will be the door switch,unplug the washer,remove the spring from around the outside of rubber boot,pull the boot off just on the side of the door switch enough just to change out the switch,put it back together.next time send the model number,i could have given you the part number,good luck
Posted on Dec 16, 2014
Why doesn't it work until I push up on the door just a bit?
There is a safety interlock that the door actuates that lets the oven run. If the door is bent, the interlock switch is not in the right position and the oven does not think that the door is closed.
There is not usually an adjustment on the interlock stud. You might try to re-align the door.
Aug 30, 2015 | Frigidaire Microwave Ovens
My machine's cycle won't start. Lights all come on but there is a lock symbol which keeps flashing, bottom left of screen. ? the door but no matter how 'positively' I shut it - it doesn't go off.
the door 'interlock' has failed
it heats up to seal a door
when it cools down it opens
{either a bimetal switch and coil or a thermister and coil}
replace the door interlock
two screws and a plug ...
method
isolate mains supply and water
open the door
take the top off {slide two screws}
take the two screws out of the door catch machine side
reach down and unclip the interlock
pull the plug
put a new one
and replace the screws
check the door catches ok
if so
plug it in
place it to drain and spin
one the spin completes your sorted
and its a common fault
Apr 28, 2015 | Washing Machines
What is the de error message
Hi Prasanthi.
On front load machines, some manufacturers us de as 'door error'. This generally relates to a fault with the interlock mechanism.
This is the door lock which prevents the door from being opened while the machine is working..
If the door won't lock and/or the machine won't run. OR the door is locked shut, then this is the most likely situation.
The interlock switch is part of the electrical circuit.
NOT recommended for a handyman.
It's not a big job for a technician, and you will probably need a new interlock.
Good luck.
Nomess
Interlock switches look like this.....
Feb 09, 2015 | Washing Machines
Hoover softwave autowasher 1000 door mechanism broken
the door interlock has failed
youll need to check the machine is empty
remove the mains power supply
and then the top lid
and use a tools small screwdriver etc
to teeze the door open
from inside
then replace the door interlock by removing a couple of screws or releases and replace it by plugging a new one in
checking the door release also for damage
all the bits youll find easy on ebay
and should cost no more than £25
if you dont feel up too the repair at least you can get your clothes back
Oct 30, 2014 | Hoover Washing Machines
I replaced the door latch onour LG model LMV1630ST when Ishut the door the light stays on and the start butten will not work. all the other buttens work.
There is an interlock that is part of the latching mechanism that prevents the oven from operating when the door is open. In the process of replacing the door, the interlock must not have been properly set. Look for a switch associated with the latching mechanism, it should be relatively obvious what is going on.
Sep 09, 2014 | Microwave Ovens
Light stays on and turntable turns when door is closed and unit not in use.
see the diagram attached, and fix it. God bless you
  • Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  • Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replace
    Jul 08, 2013 | Magic Chef Microwave Ovens
    Everything works but it will not heat food
    Check the door safety interlock micro switches. Others will po9int to the very expensive magnetron and it might be that but I don't think so. Still others will tell you that it is the capacitor ... and it might be that. If you regularly open the door while the oven is operating, the tiny contacts become damaged from the arcing. When the interlock switches can not longer tell the oven the door is in fact closed, the magnetron will not come on .. and there will be no heat.
    It is probably worth removing the cover to check the $2.99 micro switches ...
    Make sense?
    Thanks for your question @ FixYa.com
    May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    Washing Machine does not work and shows error code E40
    E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
    Most likely cause is the door interlock.
    Nov 14, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
    DOOR LATCH DOES NOT CMPLETE INTERLOCK UNLESS PUSHED IN
    hi billy
    the most likely cause is probably the interlock switch has gained some play through wear an tear replacing it may solve it but first check that the door hinge hasnt been put out of alignment by the door being pushed open futher than needed. fitting a new interlock switch is relatively easy on most models www.espares.com might have it
    hope this helps
    Oct 25, 2008 | Frigidaire FWT449
    Washing Machines Logo
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
