Question about RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet Android 4.2, LCD Touchscreen, 800x480, 6 Hours
Battery will not charge
Charging for 24 hours and still no charge
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 265 Answers
Your battery may be defective and cant hold a charge. Make sure the unit is receiving power and if so replace the battery.
Posted on Dec 15, 2014
Tablet will not charge
Assuming that you charger is not defective, and that you have no other electrical issues, then if your battery has been allowed to completely flat line, it may no longer accept a charge from the normal wall charger. Then you can try to trickle charge your tablet from a low voltage/current source, such as a USB port or a low power phone charger (5v/500ma). Try a trickle charge for 8 - 24 hours on your tablet. After that try your normal charger and see if it will now charge properly.
If that does not work, and you have previously ruled out your charger, then I would suggest contacting the manufacturer, as it is likely some other fault, either with the battery, or the tablet itself.
I post on behalf of HP.
Jul 31, 2015 | Tablets & eReaders
My zeepad not coming on charge it for a couple hours still coming on.
First Battery charge often takes from 24 to 36 hrs.to fully charge.
Dec 25, 2014 | Tablets & eReaders
I turn my tablet on then it switches it self off
Sounds like it does not have enough battery power to stay on. If you have not tried to charge it, you should try that first. If you have, it sounds like it is not getting charged or not holding a charge. Could be bad AC power source, bad charger, bad charger connection or bad battery. Take steps to confirm that each of these are good. If all of these are good, sometimes the tablet can become so discharged that it will not allow itself to charge. When they are in that state, sometimes you can trick them into charging again by repeatedly disconnecting and reconnecting the charger as follows: With charger plugged in to AC power source, connect the charger to the tablet. Pay attention to the screen or LED or whatever indicator your tablet has to let you know it is charging. You may see it momentarily indicate charging, or maybe not at all. Then unplug the charger from the tablet then immediately plug it back in and pay attention for the charge indication again. You may have to do this a bunch of times (like 20) until you see the indication that it is charging. When you do get the indication, stop unplugging and re-plugging and let the tablet charge for 24 hours (to a full charge). This trick doesn't always work. Sometimes the battery or charging circuit or an internal connection is bad and no amount of unplugging/re-plugging will fix a hardware problem.
Nov 17, 2014 | Tablets & eReaders
Kobo ereader problems
Unfortunately, the batteries on Kobo were not designed to be replaced. If the batteries will no longer accept a charge, it is time for a new e-reader.
Aug 14, 2014 | Kobo 6" eReader Touch Edition
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Charged sylvania tablet for 24 hours & unplugged it but no power
Many times the cause of this problem is u need a new piece where the charger plugs into the device because it shorts out.
Aug 20, 2012 | Sylvania Sytabex7-2 7" Tablet Express Plus...
RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet Android 4.2, LCD Touchscreen, 800x480, 6 Hours Logo
208 people viewed this question
Top RCA Tablets & eReaders Experts
Ron Dufek
Ron Dufek
ccsi99
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
