Question about Thule 2003 Dodge Dakota - Club cab - Xsporter Truck Rack
2003 dakota runs good cold.gets warmed up starts lossing power then stumbles and dies or straitens out and runs right. after stall it starts right back up and runs good for various short times.i not
Fuel presure check and code check. no codes
Starts right up but once it warms up it dies have messed with the air gas screws that's fine don't know what the problem is
My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
Dec 21, 2015 | Cars & Trucks
I have a 1996 dodge dakota 2wd took out the 5.2 and put a 5.9 in headers no cats no 02 sencers and my problem is when i start it cold idle is good but if i take it to 2,000rpm it will bog down then...
Without input from the O2's, the engine goes into fail-safe mode and runs in a full rich fuel trim. When the engine is cold the spark plugs are being "loaded up" with unburnt fuel, and engine stumbles. Hope this helps.
Mar 14, 2014 | 1996 Dodge Dakota
1989 lesabre stumbles and dies
I agree it sounds like the magnet for the cam sensor, or a problem in the wiring harness.
I don't think the engine will run with the cam sensor disconnected since it needs that signal to set base timing. It can run without the crank sensor once the engine starts.
There is a slight chance the timing chain is getting loose and affecting cam timing too. You may be loosing plastic teeth on the cam gear.
Apr 08, 2013 | Buick LeSabre Cars & Trucks
I have a 1995 dodge dakota 4 cyl. and standerd trans. I just replaced the head gasket and it starts and runs great when it is cold but after running for a few min. it stumbles and has low power, it will...
have you done a back pressure test on the catalytic convertor? may have become clogged when the headgasket gave up. normally acts up after vehicle warms up and doesn't set an engine code.
May 30, 2012 | 1994 Dodge Dakota Club Cab
Stumble off idle
Stumble off idle,you have a misfire at idle the ignition system is of concern this will include plug wires sparkplugs cap and rotor,
Mar 03, 2012 | 1995 Dodge Dakota
94 Bravada that stumbles and stalls.. won't start when warm..
Try checking the exhaust flow when someone else is pushing down on the gas petal.The farther the petal gos down,the more exhaust should be coming out. I replaced my catalitic convertor at 44000 miles, it was clogged. I had them install a high flow type.
Sep 03, 2009 | 1994 Oldsmobile Bravada
Runs fine till warms up then losses power and dies
Does the fuel line still have 55 PSI when engine warmed up? Any other codes show up?
Aug 22, 2009 | 1998 Chevrolet Blazer
STARTS & RUNS WHEN COLD BUT STALLS EVERYTIME YOU RELEASE THE ACCELLERATOR WHEN WARM
2001 dodge ram 1500 dies after releasing accelerator.runs good while accelerator is depressed.
Apr 28, 2009 | Volkswagen Jetta Cars & Trucks
95 dakota dies when warmed up
yes it can but you may have a coolant temp sensor acting up which causes the computer to open the injectors to much which can also cause this 02 sensor code. when it stalls do u have spark and fuel pressure.
Dec 18, 2008 | 1995 Dodge Dakota
Thule 2003 Dodge Dakota - Club cab - Xsporter Truck Rack Logo
470 people viewed this question
Top Thule Boating Experts
Tom Chichester
L Pfaff
L Pfaff
John Mabry
John Mabry
Are you a Thule Boating Expert? Answer questions, earn points and help others
