Question about Dishwashers
Does anybody know what e4 problem on a jan Kolbe dish washer
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: haeir dish washer
e4 error with the temperature sensor
Fix it .
God bless you
Posted on Oct 03, 2012
I have a ge profile washer and I get an e4 error code
Hello Lisa;
My name is Peter. I am a retired field service appliance technician.
You did not provide any information so I have to be general.
1.) I assume this is a clothes washer and not a dish washer?
2.) What is the model number? It should be on a label on the face of the unit after you open the door.
3.) The E4 error code on your model washer is an inlet valve failure. Does washer seem to fill up with hot and cold water at a steady rate?
Mar 20, 2015 | GE Washing Machines
General electric washer says e4
General electric washer codes are explained on this webpage.
http://www.appliancepartsquick.com/GeneralElectricWasherFaultCodes.html
But I cannot find E4 listed. It is hard to work out without knowing the exact model number of the washer.
If you have a commercial washer then E4 is showing up as a pump blockage or fault.
Check this document on page 5.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90149.pdf
Aug 28, 2014 | Washing Machines
Haeir dish washer
Fix it .
God bless you
Oct 02, 2012 | Dishwashers
Showing error code E4
check for waterleaks filling the overflow tray at the bottom of dish washer that is activating the float switch. check for defects or damage at bottom of dishwasher.
Feb 01, 2012 | Bush Dishwashers
How to reset error code e4 on delonghi dishwasher
Remove all dish trays from washer, unscrew and remove lid off salt softner, tip machine on side untill all water drains from the salt softner, replace all trays and softner lid and machine should work again.
Dec 08, 2009 | Dishwashers
Continuous beeping and code E4 on display
"E4" code relates to the overflow detector There appears to be an internal sump. Lean the machine back about 35-45 degrees to remove the excess water from the dishwasher. It might be messy so be prepared. By design the sump collects water from condensation i.e. (Cold outside machine wall, hot inside machine wall) hence condensation builds up and is suppose to and should evaporate in the right environment. Placement and installation locations play into a big part of the design.
You will notice by observation just in the center there is a polystyrene float. This is what activates the overflow switch which throws the error code.
This problem is simple to fix, just take off your kitchen plinth and turn off the dish washer power. then at the base of the dishwasher there are 2 plastic clip access panels, take a blunt screw driver or knive to help you ease out the plastic panel. once this is off, simple take a dish cloth out mop out the water, particularly from the left hand side as this is where the sensor is. Once dry (ish) replace the panels and switch on - DONE! its that easy
Jan 19, 2009 | Dishwashers
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
DISHWASHER HELLER DWH3
my heller dish washer has a error code e4 ? where can i find what this means
Apr 27, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
