Question about Garden
Looking for o-ring for 1992BHG pump sprayer
Need o-rings part list
4 Suggested Answers
SOURCE: replace 0-ring
all I want to know is how I can get a replacement o-ring ASAP without paying to discuss my needphone number and person to call would be helpful.
Posted on Mar 24, 2009
agent91
  • 2100 Answers
SOURCE: GUN WILL NOT PUMP (CEPIA 1 TOUCH ELECTRIC SPRAYER
Regular O-rings off the shelf at any hardware should fit this thing. They come in those boxes of all sizes, the only ones you won't find are the little tiny ones. About 1/16 inch. Your gun shouldn't have any that size. You can buy a new pistol for about $8.
Posted on May 06, 2010
ceilinstal
SOURCE: need an o ring
Check with the guys that fit tyres..They normally have a variety of these O-Rings.. Not sure what they use it for but it worked for m
Posted on May 18, 2012
Better homes 1201 bh sprayer parts I need a o ring.
Take your old o ring to Autozone,they sell a sort ment pack for 3.99,it's on the parts rack.
Aug 01, 2017 | Cars & Trucks
Button on sprayer is sticking with no spray
This is typical behavior or sprayers that aren't looked after. Mine typically last 20 years. After use, you need to empty it, wash it, pump the soap through, rinse it, pump the clean water through, empty it and blow air through it. Then leave it open to dry.
Take the wand off, and take everything apart and soak the parts in hot soapy water in your bathtub. Rinse and dry, rub any o-rings with vaseline.
Apr 23, 2016 | Garden
Sprayer pump on a 32oz spray bottle stoped working
Seals, did you fill it recently and drop the o ring or seal?
Check and clean all o ring or seal under filler cap.
Nov 16, 2017 | Delta Garden
My solo backpack sprayer won't pump up when I use the handle. What's wrong and how to repair it?
chabunga offered really good info...except for the suggestion to use Vaseline on the 'O' ring. NEVER use Vaseline on anything rubber, because it is a petroleum based product and it will cause the ring to deteriorate. Use a non-petroleum based lubricant instead.
Jun 03, 2012 | Solo Backpack Sprayer
Need an o ring
May 18, 2012 | Cepia 1 - Touch 1/2 Gallon Rose & Garden...
I have a gilmour xp30. The pump assembly will not pressurize/blow air out the exhaust port. (There seems to be a part rattling inside the cylinder). Can it be fixed?
there is an O-ring in the plunger tube that can slip of its channel seating if it becomes dried out. To put it back you need to disassemble the handle from unit. At base of handle is a lock that looks like a cross. It is difficult to turn because it has small protrusions at the ends that snap into holes in the collar. Once you turn them and the pop out the handle can be removed exposing the pump shaft. The O-ring is probably what you hear rattling and will be loose in bottom of tube. Just put it back into its grooved seat, slide plunger back into unit, rotate the x-lock till it snaps back into place and unit should work again. I have oiled o-ring but that did not last long and might get oil on plants. I now just spray some water down the top to lubricate the O-ring when it seems dry.
Aug 22, 2011 | Gilmour & Spray Doc& Poly Tank Sprayer...
May 05, 2010 | Cepia One Touch Pistol Motorized Power...
The middle and top sprayer is not rotating, causing dirt to remain on the dishes. What controls these sprayers?
When you push the top drawer back to close the door the arm engages into what looks like a small doughnut this is where the water is pumped through your machine.
Both the middle and lower arms get there water this way. Take the lower basket out completly and look at the end of the arm where the water goes in has you lost the small rubber sealing ring it's usually orange in colour and forms a seal when the door is shut.?
If this rubber ring is missing the water will not get pumped to the top of the machine it will just flood out of this connection.
Nov 07, 2009 | LG LDF6810 Built-in Dishwasher
Replace 0-ring
Mar 23, 2009 | Gilmour & Spray Doc& Poly Tank Sprayer...
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
