Question about Magic Video Game Consoles & Games
How to install magic ultra 2 on my computer.
I can not install magic ultra 2 on my computer.
  • Julio Gassette
    Julio Gassette Dec 22, 2016
    How to install magic ultra 2 on my computer for mac
Magic box information and access code computer crash
I'm afraid you're out of luck. I was in the same boat, wanting to install the Magic Box on another computer ... but the company is out of business, and you need an access code when installing the software. You may know this by now, since it looks like you posted the question a couple months ago. However, I found out there is a way to upgrade your 330 so you will not need the Magic Box! If you are interested in the information, I'm happy to share. I don't know how this forum works, whether you can contact me back to ask for details?? I see 2 other posts with the same type of question, so I'm posting the same response on all 3.
Apr 08, 2016 | Magic Sewing Machines
Magic jack customer service
If your tv has internet access and you can run their software on it then it will, otherwise no.
Aug 30, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
Old majic jack want to start new program
If you have an old Magic Jack, my 4 unit are 6 years old the company just really wants you to upgrade to a newer product no need to. Try removing Magic Jack completely from your tablet, restart unit, make sure to clean out all junk on tablet from Magic Jack you could try a program that cleans your tablet for you, but unless you know what to remove don't get technical just a standard clean up of old files, this is usually under apps, Magic Jack, then there will be a clear cash button, clear data, and uninstall.
Restart unit then do a fresh install of Magic Jacks new app for your type of tablet from Googles sight or Magic Jacks make sure if you have a Mac to install the Mac App and if you have an android tablet you install the Android App. This has been working for me. With the old Magic Jack you will need to do a fresh install when you get errors and crashes. I do it 2 or 3 times a year. Good Luck!!
Jan 06, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
Need magic Jack plus software download
Magicjack software is stored in the Magicjack module. Plug that module into a USB port on your computer. You should get an onscreen message like: "Install or run program from your media".
Click on "Start Magicjack". That will install the software on your computer.
More information at:
Jul 29, 2012 | magicJack Two, 2 Magic Jack Plus Voip...
I bought serious magic visual communicator pro 2 on but the product key is not working. I called adobe and they said that I should ask for a refund. I am not sure that the seller will give me a...
Issue Activation fails when you attempt to install and launch a legacy Serious Magic product.
Reason Adobe has chosen not to renew the hosting account for the Serious Magic web site. The hosting contract expired on Nov. 3, 2008. Activation for Serious Magic products that rely on this server is no longer supported by Adobe. SolutionDo one of the following:
1. Upgrade to the latest Adobe-branded version of the product.Note: DV Rack is now Adobe OnLocation. The most recent version of Adobe Ultra was Ultra CS3. Ultra was not included in CS4, however, color keying is available in After Effects CS4. A tutorial on basic color keying is available here.
2. Download and run the Serious Magic legacy product activation tool.Instructions for SMActivate.exe:
  1. Extract the .zip file to a convenient location.
  2. Double-click SMActivate.exe. The application will display a list of Serious Magic products to be activated.
  3. Click OK.
Your product is now activated and ready to use. If no qualifying products are detected, it will display the message: "No legacy Serious Magic applications detected."
This change affects the following Serious Magic products:
  • Ultra NTSC VxxV
  • Ultra PAL XxxX
  • Ultra 2 PAL BPWB
  • Ultra 2 NTSC BNWB
  • Visual Communicator 1 Studio SxxS or TxxT
  • Visual Communicator 2.0 CxBC
  • Visual Communicator 2.0 Web CxWC
  • Visual Communicator 2.0 Pro CxPC or CxQC
  • Visual Communicator 2.0 Studio CxSC or CxTC
  • DV Rack DxxD
DV Rack Express requires a special version of the activation tool, available here. This affects the following Serious Magic product:
  • DV Rack Express FxxF
For DV Rack Express, do the following:
  3. Select the checkbox for DV Rack Express.
  4. Click Activate. This will create a file, smact21.db, in the C: root.
  5. Move that file to c:\program files\serious magic\dv rack express\bin
The following Serious Magic products do not use activation, or use alternative activation and are not affected:
  • DV Rack 2.0*
  • Ovation
  • VlogIt!
* DV Rack 2.0 uses activation through a third party company named Softwrap, which resides on a server that is not affected.
Note: Ultra CS3 is an Adobe product and is not affected.
Dec 21, 2010 | Serious Magic Visual Communicator 2 Studio...
We recently installed a new replacement router WRT 160N V3 and something called Network Magic keeps interupting and trying to sell their service. We keep canceling them and then the router does not work...
To clear out the problem if Network Magic has something to do with your connection.
1) Uninstall Network Magic from host computer.
2) Remove Ethernet connections to router.
3) Reset the router (press & hold reset button for at least 15 secs.)
4) Run Setup wizard on host computer and follow on screen instructions on connecting PC to router.
5) Setup wizard prompts on installing Network Magic, just ignore it.
6) if it automatically installs Network Magic just uninstall the program before you fully use your router.
Resetting router clears all settings made by Network Magic application made on the router.
Hope this helps.
Mar 13, 2010 | Linksys Wireless-G WRT54G Router
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Registration fix for Ultra 2
Dec 16, 2008 | Serious Magic ULTRA (20020000E) for PC
61 Hitachi Ultra Vision has double image
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
Jul 17, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Windows did not detect SATA during installation
You need the manual to your motherboard to set it up in the BIOS. In the drop down menu select M7NCD ULTRA. I hope this helps. Let me know.
Jun 30, 2007 | Biostar M7NCD ULTRA Motherboard
Video Game Consoles & Games Logo
81 people viewed this question
Top Magic Video Game Consoles & Games Experts
Martin Murray
Are you a Magic Video Game Console and Game Expert? Answer questions, earn points and help others
