Question about Music
Hello. I just bought myself a kayboard, used. One of the notes work 50 % of the time. The other 50 % it playes at max volume. Is this a normal problem ? Is there any easy fix to this problem ? T
I havn't tried anything to fix it yett.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
That's a contact problem. Easy fix but disassembling the unit is difficult. Take it to a service center.
Posted on Dec 18, 2014
  • Henrik Thomassen
    Henrik Thomassen Dec 19, 2014
    Thanks, the problem suddenly went away, but ill do that if it returns
2 Suggested Answers
  • 5603 Answers
SOURCE: Hello! I've bought a Fender Rumble
Try plugging another sound source into the unit. The buzz MAY be pickup of magnetic fields in your guitar pickup that clobber your notes from the strings. Bad guitar cables are another possibility. By putting clean music from say a CD player into the unit you can find where the source is. If the CD player generates the same noises, then likely you have a failure of filter caps in the amp or other component failures. Also make sure your guitar can't "hear" the amp as feedback can do strange things.
Posted on Apr 23, 2011
Volume keyboard
Go into function and look for the volume setting for your main voice - could be R1. This will give a numeric value of 127 or less. It sounds like you need to increase it, try 100 as that is usually sufficient.
Dec 27, 2013 | Yamaha DGX230 - Digital Piano
Very low volume on all drums.
I don't think there is anything wrong, it has a very low line level output intentionally. This is to minimize distortion to an amp or mixer. Mine is the same and also a different brand. It is actually made so you could play it through a stereo without damaging it.
Mar 06, 2013 | Alesis DM6 Electronic Drum Set
Disfunctioning f note. It plays extremely loudly.
If it is under warranty, may as well make use of it. In the long run it will be less headache for you.
It is something that should be repairable, although time consuming. as it is likely a stray bit of solder lodged where it should not be.
Feb 06, 2012 | Casio CS43 Stand for CDP 100
Hello, I own a hotrod deluxe. I take great care for it and never move it. Normally on the clean channel, the volume is regulated by the volume and the master. Today the amp sounded only half as loud as...
Do you turn on standby every time and wait for the tubes to heat up first? If you don't, it can severely damage the tubes.
But a common cause of this could be just old tubes. Like any other piece of technology, tubes get old. If you like to play your amp LOUD then they wear out a lot quicker. You have to replace tubes every now and then. Because I'm not there to check out your amp, I can't give you an exact answer but it sounds like that's the problem. This isn't always a bad thing. You can make the sound of your amp exponentially better with nicer, new tubes. Your amp has 12AX7 tubes. Very common tubes to use actually. I'm not sure what kind of music you play, I'm assuming mostly rock and blues. But here is a list of tubes and reviews on them.
http://thetubestore.com/12ax7review.html
This is how to replace a tube:
http://www.ehow.com/video_4438285_change-pre_amp-tubes-guitar-amps.html
Upkeep on a tube amp:
http://www.ehow.com/video_4438295_replace-tubes-guitar-amp.html
A note he doesn't make in the video is to dust out your amp. I use the compressed dust spray for the inside of computers.
So overall, stop turning up your amp to 11, make sure it's well ventilated and dust it out from time to time. Hope this helped.
Jun 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
I have a RH50 T amplifier, it had a bit of a bumpy car ride to band practise the other day and now when i play through it, it will make a permanent buzzing noise on the clean channel that gets 70% worse on...
You may have damaged the variable resistors (the volume controls), you can purchase replacements from a local Electronics store (if UK based try Tandy). Otherwise have you checked the speaker itself for damage? You may have split the speaker which will need to be replaced.
May 04, 2011 | Randall RH50T Tube Series 50-Watt Guitar...
Hello! I've bought a Fender Rumble 75 about 3 months ago and it sounded great really but after some loud playing (About 75% of max volume) it started to buzz at midrange notes, and its gets worse as time...
Apr 23, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
When I'm playing on my amp there is a strange noice coming out of my amp. At first I thought it was my guitar, but it is really my amp... does anyone know how to solve?
"A strange noise" does NOT give us much to go on...
Please note that relatively low volume digitizing noise often exists from teh digital effects processors... it should be well below the normal playing volume.
Aug 09, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
My xp-50 is emitting a noise when the keys are pressed
If the level is very low, this is what is known as "digitizing noise".
The waveforms from synths being digital in nature, have sharp edges that are filtered. There is a fine line between filtering too much and too little.
There is ALSO the statistical noise that is present in electronic devices that you can notice when you turn the volume way up.
These are all NORMAL and the nature of the beasts.
Nov 28, 2009 | Music
Neck and Middle pickups make little sound even with volume at max
Hi There!!
I am a gitarist myself too and firstly let me tell you u have purchased an excellent guitar to begin with!!
Now about the Neck\blues pickup.....If you say there is little sound this can be because of:-
1)Faulty bridge adjustment
2)There can be a problem also because of  the neck of the guitar being a bit bent in or around the place where u have the pick-ups though the chances of that are rare.
If there is no sound then please contact your dealer to change the piece....
Have a great time playing
Hoping this helped.Any help regarding the above steps , feel free to ask them.
See ya.
Dont forget to rate
Mar 14, 2009 | Yamaha Electric Guitar
Music Logo
27 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
