Comment changer l'heure
Caisse enregistreuse
  • Computers & ... Master
  • 5,660 Answers
N'parlez vous Francais
I'm sorry my French is a little rusty,,,,are you asking about changing time and date on your desktop computer?
Put your mouse cursor on the time, then Right-click on it.
Change the time and date.
If the time and date changes back after you have reset it, then you have a bad CMOS battery. Replace it.
This is a type of watch battery. Generally it is a CR2032.
This flat coin looking CMOS battery is located on the motherboard.
Make sure the computer is off and unplugged from power.
FOLLOW anti-static precautions. (If you do not you will fry out the computer)https://www.youtube.com/watch?v=ao866I9XpTo
Remove the CMOS battery and replace.
If you come back in a Comment, and state the computer manufacturer name,and model number, I should be able to lead you step by step in replacing the CMOS battery.
Regards,
joecoolvette
Posted on Dec 15, 2014
Caisse enregistreuse SAM4S modele 285
try this link for programming tax rates
http://www.cashregisterhelp.com/SAM4s/285mpro.html
Mar 20, 2012 | Samsung Computers & Internet
Bonjour je veux changer l'heure sur modele intermatic et70215c envoyer document en francais merci, juleslafond@qc.aira.com
1) Je ne parle pas fran?ais.
J'utilise google translate.
http://translate.google.com/#
2) J'utilise navigateur add-on: IMtranslator
s?lectionnez le texte dans le navigateur, puis cliquez sur IMTranslate
http://imtranslator.net/ff-plugin.asp
3) paragraphes copier et coller du manuel.
coller du texte dans Google Translator
Traducteur utiliser pour aider avec le manuel
traduction n'est pas parfaite, mais il sera probablement assez bon
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70215c%20-%20english.ashx
4) Je sais comment programmer le ET70215C
Je peux vous aider
»ajouter un commentaire" et il m'envoie e-mail
garder question simple et courte
5) aussi
contacter Intermatic
Intermatic est hors ligne le samedi et le dimanche
http://www.intermatic.com/customer%20service.aspx
May 05, 2011 | Intermatic ET70215C Electronic Energy...
How do i set the time on a dunlop sports watch?
Ma montre , spur DUNLOP dun 103 g10 , est pourvue d'une feuille explicative concernant un mod?le diff?rant !
2 personnes ont pass? des heures ? essayer de la r?gler sans succ?s
comment ? puis-je la rendre fonctionnelle ?
Merci de votre r?ponse
Meilleures salutations
Gerry GRAEF
50, rue du Premier-Mars
CH-2206 Les Geneveys-sur-Coffrane
Sep 23, 2010 | Bulova Watch
Comment faire pour changer la combinaison d une serrure bouton simplex
English to French translationJ'ai trouv? cette instruction ailleurs sur ce site (merci ? pctuneup191):
PROC?DURES POUR CHANGER LA COMBINAISON DE S?RIE CIPHER SIMPLEX 1000 SERRURES
1.) ASSURER LA PORTE EST OUVERTE.
2.) Introduire la cl? CONTROL DF-59 ? l'Assembl?e de changement de combinaison (SUR LE DOS DE LA
PORTE) et d?visser le cylindre en tournant le CLE.
3.) Consid?rer que l'Assembl?e PLUG changer compl?tement hors de la porte.
4.) Tournez le bouton PORTE EN DEHORS dans le sens horaire jusqu'? ce qu'il s'arr?te, puis la rel?cher.
5.) PRESSE DANS L'actuelle combinaison FERMEMENT.
6.) Ins?rer la cl? de b?tons dans les roues MANCHON changement de combinaison. IL YA INSERT sur les neuf
Heures.
7.) Tourner la cl? CLE DOUCEMENT montre jusqu'? ce qu'il s'arr?te ? la position 12 heures. NOTE
Les encoches de combos LA MANCHE CHANGEMENT QUE le manchon est d?plac?.
8.) Tourner la cl? CLE ANTIHORAIRE RETOUR ? la position neuf heures jusqu'? ce qu'il s'arr?te.
Retirer la cl? CLE.
9.) Tournez le BOUTON DE PORTE EN DEHORS (tout le chemin, jusqu'? ce qu'il s'arr?te), puis rel?chez.
10.) Taper la combinaison en appuyant sur les boutons. Utilisez au moins trois chiffres et un
maximale de cinq ans.
11.) Tournez le bouton PORTE MONTRE UNE FOIS, tout le chemin, jusqu'? ce qu'il s'arr?te. HOLD dans cette position et
VERIFIER SI LE p?ne est r?tract?.
12.) COMMUNIQU? la poign?e de porte.
13.) Tournez le bouton PORTE DROITE One More Time ? la position STOP. ? ce stade, LE LOQUET
Doit pas se r?tracter sauf si vous utilisez la nouvelle combinaison.
14.) REINSERT la bouteille dans le dos de la porte en la vissant dans une montre avec la DF-59
KEY CONTROL (NE PAS TROP!)
Retirer la cl?.
Un Df-59 cl?s peuvent ?tre achet?es sur ce site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
La cl? de serrage (SMPBC201278 Simplex: SpannerWrench 9,00 $) vis?s peuvent ?tre achet?s sur ce site:
http://www.ckilock.com/Mpage18.asp
Vous trouverez un lien pour t?l?charger le manuel de votre mod?le sur cette page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Ce sont des fichiers PDF, n?cessitant Adobe Reader pour ouvrir. Il ya un lien sur la m?me page pour t?l?charger Adobe Reader.
Service ? la client?le peut ?tre contact? directement depuis ce lien:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Assistance technique ? partir de ce lien:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Bonne chance!
Sep 09, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Comment puis-je changer l'heure
  1. Alllume ton GPS.
  2. Tape quelque part sur l'écran. Des icônes apparaissent.
  3. Cherche celle en dessous de laquelle est écrit 'Change preferences'. L'icône en question représente une clef plate (de mécanicien) .
  4. Tape l'icône pour changer la configuration.
  5. Utilise la flèche qui pointe à droite. Continue jusqu'à ce tu parviennes à la page où il y a l'icone d'une horloge (réveil-matin).
  6. Tape cette icône.
  7. On te demandera de choisir entre la représentation de 24 h (18) ou 6 pm. ou 6. Choisis ta représentation horaire.
  8. Dès que tu appuies sur Done, l'écran change et on te demande de régler l'heure.
  9. Tu as des flèches vers le haut et des flèches vers le bas. Deux flèches pour changer l'heure et 4 flèches pour changer les minutes.
  10. Tu peux même synchroniser l'horloge sur les sattelites en appuyant sur sync.
Jul 19, 2010 | Tomtom ONE GPS Receiver
My tag heure chrono's minute and second hands turned black and moisture got in ?
mcdevito75 here, I hope you have a warrantee on your Tag Heur watch, if so, contact Tag Heur, if not, your on your own, (Sorry) sounds as though it"s lost some of it"s waterproofing ability or the seal around the crystal, usually a crystal sealer. Best Bet look for a small watch repair shop in your area, have them take a look at your watch. The Fog on the crystal is the tempersture change of the air in your watch, no watch is air proof, re-sealing the crystal should help, also, replaceing the rubber seal on the back of the watch.
Jul 18, 2010 | Tag Heuer Watches
Picture freezes up - we have already replaced the lamp. Can this be the color wheel.
i think your computer is infected with virus called win 32 heur. To confirm if it is infected with heur or not. Right click in the desktop and mover the cursor to sent to . If it freezes then your computer is surely infected with heur. You can also scan with Agv 8 to know.You need to reinstall the xp to repair
Nov 03, 2009 | Samsung HLN5065W 50" Rear Projection...
The CD Changer will not work and shows ERR 1 and I
The cd changer internal mechanism is faulty, replace the cd changer itself.
Jun 04, 2009 | 1999 Audi A6
Casio PCR-T275 Tax settings
Comment je programme les taxe de tvq 5% et tps 7.5 % pour le québec sur ma caisse casio pcr-t275
Feb 17, 2009 | Casio Parts Cash Register PC Desktop
Casio tek 7000 reinitialisation?
Hi. I may be able to help if you can post in English.
Mark
Sep 21, 2008 | Casio Parts Cash Register PC Desktop
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
