I have a 50" Philips plasma and my screen won't turn on. But the TV seems to be getting power because the standby light blinks and the side ambilight system turns on. I was wondering which board is most likely to get it working if I swap it out for a new one?
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty
Posted on Dec 16, 2014
  • 8457 Answers
SOURCE: 50 in philips hd plasma with ambilight model number 50PF9631D/37
The backlight inverter board is going just not dead yet.
U need a new board.
Posted on Sep 10, 2009
SOURCE: I have a Philips 50 inch plasma tv. The light is
I have Philips 50 inch plasma TV purchased almost exactly 3 years ago. Completely out of warranty. Paid 1999 bucks for it new. Now Plasma TVs similar to this are 800 bucks. I figured the cost of a repair tech coming to the house would be around 500 bucks.. so I decided I could "do no harm" and look at the power supply. Sure enough, two 3300 uF caps were swollen.. I am far from a true electrical repair person, and if it were not for the caps being swollen, would have no idea that they were bad. I am however a little bit skilled in soldering. So I ordered replacements for about 8 bucks. The caps were actually only 1.50 ea. but the min order fee and shipping brought it to about 8 bucks.. I got them from studiosoundelectronics.com . They came in today and installed them... to my astonishment, my TV works as good as it did when it was new... I must say that I am dissapointed in Philips.. and will never buy another product from them. If it is out of warranty.. they will not even talk to you.. I don't think it is too much to ask when you spend 1999 bucks on a product from them.. I expected my TV to have more than 2.999 years in life in it. Thanks a million to this site for providing soulutions for folks..
Jeff
Florence AL
Posted on Oct 03, 2009
eagle338
  • 4889 Answers
SOURCE: Philips Cineos flat screen TV
Sounds like an issue with the power supply board. We will have to go component by component and you will need to knowledge of using a multimeter. If you are skilled enough to do this then let me know and I will help you troubleshoot it.
Posted on Mar 19, 2010
  • 2318 Answers
SOURCE: My 50 in philips ambilight plasma will not turn on
The failure with your plasma is with defective capacitors in the power supply.
Check the link below with info on how to DIY.
http://www.fixya.com/support/t5048641-easy_replace_capacitors
Posted on Jul 31, 2010
SOURCE: LG 50PC3D 50in. plasma.... TV works
Hi, this could be a problem with the power supply in the tv, it is common especially on some Samsungs and specific repair kits are available quite cheaply if you have good soldering skills, this can also apply to many other Flat Screen TV's .
Usually this is caused by capacitors that have dried up and split, you can normally tell as the capacitors are bulging on the pcb, you can get them in a kit as I said eBayer's sometimes do them or you can buy them indivually from a good electronics components supplier, make sure you get the correct values for each!! marked on the side of the capacitors in xx/x V, xxx/x uF and 105oC. (the x's represent numbers)
The picture below shows the type of theing that happens, the brown ones are bulging/split on the top whereas the black one is fine.
High Voltages can exist in these sets, never attempt anything while plugged in and
if in doubt do not attempt it yourself and seek the advice of a qualified TV Technician.
There could also be dry solder joints on the panel, usually applies to the power supply as it's mainly these get the hottest.
Here's an example of what dry joints look like.....
It's also worth considering claiming under the warranty for replacement or repair through you dealer if warranty is valid.
Hope this helps
Midge.
Posted on Feb 12, 2011
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
Phillips ambilight TV Flashing red LED light--- ^ long blinks and then 3 short blinks--- picture and sound will not come on---
Check the tv power supply board for those dying parts call copactors.That the board,where the power a/c cord plug into it.These capacitors are alway bulges or puffing up on it tops.U have tools and know basic electronic?Replaced those dying soon to be dead capacitors,will fix the power supply and have stable tv power again and tv will work.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 23, 2010 | Philips 50PF9731D/37 50 in. Plasma...
My 50 in philips ambilight plasma will not turn on and blinks a red light 7 times and repeats
Jul 16, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
The philip 50inch plasma tv i own has ambilight on both sides of the set. the light on the left side of the tv no longer seems to be working. is it simply a matter of changing the light on the tv...
you must replace the circuit board that illuminates display....you will see two(2) boards that look alike...take back off tv and you will understand.....1 of the circuit boards is bad and must be rebuilt or replaced!!!ckt boards are on the sides of TV...only 1 of them bad they both look alike . gl
May 19, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips plasma ambient light won't turn on at all and there are no blinking lights
Possibly your Ambilight module has gone bad. The part number for it is 313926809131 and runs around $200.00. I would have a technician look at this to verify the issue as well as the part number provided as Philips commonly has several part numbers for their TV's. Then again is it worth it to fix the issue if the TV still works ok itself?
Nov 17, 2009 | Philips 50PFP5332D 50 in. Plasma...
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Jul 30, 2009 | Philips 42PF9631D 42 in. Plasma Television
Phillips ambilight 50 in red light problem
I had this problem on a 42" Philips Ambilight. After reading in another forum, opened up the back, and found 2 leaking capacitors on the center circuit board (main power supply pc board) toward the bottom. Tops of the capacitors were bludged out (10v 3300uF) and leaking electrolytes. Unsoldered the old ones myself, went to Radio Shack. They were out, so order 12 on ebay for $6.63 including shipping. Resoldered and works fine. Can't do it yourself? Take the board out (just unhook the cables & unscrew it ), and take it to a computer shop or tv repair or someone who knows how to solder, and have them change them. Piece of cake!
Jul 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Plasma will not turn on
Sounds like u might have a bad power supply
Apr 05, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
