Question about Salter Aire Plus Compressor
How do i get a replacement unit my doesnt work unit 8350
Nothing
Epson 8350 both lamp and temp red lights come at startup?
I'm being told it is the auto iris adjustment that is the problem. More than likely warranty or manufacturer work. It is internal.
Jul 28, 2014 | Epson Powerlite Home Cinema 8350 Eh-tw3600...
Early today, I inserted a 8350i's battery to my 7100i and it started all right. I bought my own battery for the 7100i and I am charging it right now, and no response.
try disconnecting the charger and disengage the battery..next, put the same battery on and charge it.if it doesn't work, insert your 8350 batt again.. if it the 8350 works, your new batt is defective., if not, you may have damaged your phone because 8350 is not the specified batt for your 7100..contact me if you have further questions. o9l8 45o 554sven. GOD BLESS..
Mar 30, 2011 | RIM Blackberry 7100i
Left singal light doesnt work ,park light does, nothing works when i pull hazard button
it sounds like the flasher unit, if the flashers dont work. or if what i am reading is that the blinker dont work, but parking lights do untill you pull the hazard switch out then it is a faulty turn signal unit would have to replace it..
Dec 12, 2010 | 1988 Ford Bronco II
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
I need to unlock my blackberry 8350 i to be used with boostmobile?
you do not have to unlock it, it will do yuo no good, you need to locate the boostmobile service books and install them for your internet and texting to work, google the word "BoostBerry" and you can pay like $12.00 for the download and it really works, my brother did it and it works just like nextel
Nov 15, 2009 | Nextel Cell Phones
R-8350, No power to touchpad, but interior light works
The touchpad has its own fuse which has probably blown due to a surge perhaps related to the turning on of the fridge. Removing the cover from a microwave is potentially lethal due to the large capacitor to drive the magnetron. However, this is usually well away from the front panel. If you do venture in you should first unplug the unit and when the outer cover is removed, discharge the large capacitor with well insulated pliers -= otherwise keep well away from it. The fuse you are interested in is on the pc board behind the touchpad. Replace it with exactly the same fuse (usually a slow blow fuse).
Sep 22, 2009 | Microwave Ovens
My LG 8350 is snapping in half
I don't see a problem statement here that needs a solution by someone else.
Broken hinges on LG VX-8350 are notorious failure mode for this model. You may be able to find and obtain a water-damaged phone for small money and transplant only the keypad shell body (the broken hinge part) to your phone. To separate the keypad and screen shells on the good body unit, look here:
http://www.fixya.com/support/t1525077-repair_broken_hinge_verizon_lg_vx8350
Aug 26, 2009 | LG VX8350 Cellular Phone
I can't get my laptop to accept my lexmark 8350 printer. sometimes it accepts it and other times it doesnt.
Try uninstall the drivers and reinstall again following the instructions and see whether it works.
Aug 10, 2009 | Lexmark X8350 InkJet Printer
Salter Aire Plus Compressor Logo
485 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
solver2010
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
