Pushed 3 buttons in a sequence 3 times all lights lit up green except for lock door solid red door closes but doesnt lock machine wont start
  • 27 Answers
Replace the door lock. It's saying the door switch isn't registering.
Posted on Dec 18, 2014
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
How to program my new control remote to my Honda passport 2000
Try this please!
'98 - '02 Isuzu Rodeo and Trooper and Honda Passport(with factory keyless entry) Instructions for programming. 1. Get in car and make sure all doors are unlocked. 2. Open driver's door and leave open. 3. Put key in ignition. 4. Turn key to 'on position' (dash lights on, but do not start) and back to 'off position' 3 times in 5 seconds or less. (you must turn the key very fast) 5. Close and open driver's door 2 times in 5 seconds or less. 6. Turn key to 'on position' and back to 'off position' 5 times in 5 seconds or less. (turn key very fast) 7. Close and open driver's door the doors should lock and unlock twice after this happens push the lock or unlock button on the remote, doors will lock and unlock. Push the lock or unlock button a second time and doors will lock and unlock again. You are finished! The above sequence erases all previous codes and adds the new code as #1. If you are adding a second remote, you should follow the same sequence with the exception of step 6; instead of turning the key to the 'on position' and back to the 'off position' 5 times in 5 seconds or less, do it 3 times in 5 seconds or less and then continue to step 7. ***Remember to turn the key to the on and off position very fast. This works! Follow directions EXACTLY. I had to try 3-4 times before getting it to work. I failed to go exactly by the instructions the first few times.
Jan 03, 2013 | Cars & Trucks
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
All of a sudden our garage door stopped working and the light flashes 10 times. Liftmaster Model 2265 1/2HP. Any ideas?
We just had the same problem this morning (cold weather can mess these things up). Not sure what you mean by "not working". Ours would open part-way and then stop (or close part-way and then stop), but could open/close all the way if we held the button on the wall down the entire time it was lifting. After much research online, we ended up checking the sensors at the bottom of the garage door tracks to make sure that the green light was solid (not flashing). Ours flashed a bit, so we cleaned the "eye" and tightened it in place. Once the green was solid, we thought we were done, but still had the problem.
Then we began adjusting the screws on the unit itself that show pictures of the door opening and closing. We thought we were adjusting the torque in the unit (because we read online that cold weather can make it more difficult for the motor to work), but in reality we were adjusting the opening and closing "distance". Apparently cold weather can also do something to the tracks, which can require adjustments to be made. Something to do with ground swelling...
Anyway, we also discovered that when we had closed the door manually (red pull-cord) the night before for lack of a better solution, it never properly locked back into position, which was adding to the problem.
So, first, try cleaning the sensors. You need a solid green light for them to function properly. Second, if you have used the manual cord, make sure the arm that it attaches to is locked back into position. You can accomplish this by pulling the manual cord, manually closing the garage, and then pushing the button on the wall. The door arm should lock into place. Third, try using a screwdriver to adjust the open/close distance. Start with a 1/4 turn for each position, and play with it until you find the right setting.
If these suggestions don't address your problem, this link worked for us...http://forum.doityourself.com/doors-windows/368278-garage-door-wont-go-down-cold-weather.html
Oct 10, 2009 | Electrical Supplies
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Remotes don't work (3)
Did you inadvertantly hit the "vacation lock" button on the Mounted push button? This will cause the remotes not to work. Try hitting the button again, and then see if the blinking goes to solid green.
Good Luck
Jan 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
