Washing machine water overheating - Washing Machines
    Problem Solver:
  • 9 Answers
Possibly a thermostat problem or alternatively a circuit board problem. If you are attempting a DIY solution, you will probably need the service manual for your particular model. I tried to replace a thermostat on my last washing machine, a Zanussi, but I eventually found that the part was no longer available and so I gave the machine away on FreeCycle.
Posted on Dec 15, 2014
Machine fills, agitator not working, washing machine empties
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
May 29, 2015 | Washing Machines
Machine is on but will not run; what could my problem be? Model number WA80V3
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Apr 04, 2015 | Samsung Washing Machines
Asko washing machine w660 "Temperature stop failure"
DOES THIS MODEL WASHER ACTUALLY HEAT THE WATER? OR JUST ALLOWS A CERTAIN AMOUNT OF HOT WATER TO BE RELEASED OR MIXED WITH COLD WATER? U CAN CHECK THE SWITCH WITH A MULTI METER FOR OHMS OR CONTINUITY NO NEED FOR A TECH GUY
Jan 10, 2014 | Asko Washing Machines
My siemens varioperfect washing machine won't start the program. The lights are on but no water starts flowing. I checked water supply and cleaned the filter.. It doesn't give me any error codes. Does...
Probably your selenoid water valve is bust/ faulty. Need a new valve, not expensive, Can be caused by overheating during a period of low/ no water flow.
Dec 09, 2013 | Siemens Washing Machines
My Kenmore Washing Machine Model 110.82872100 goes through the wash cycle then gets to rinse cycle fills with water makes a clicking noise and stops. Does not drain but cycle knob moves. An electrical...
Your motor is getting overheated in wash cycle. if you turn it off for about 15 minutes and start it back up in rinse cycle will it work ? If yes, then motor is overheated. A sign that the motor is over working its self and time for a new motor.
Dec 15, 2010 | Washing Machines
My washing machine will not drain,
2or 3 possibilitiies .faulty lid switch...if machine spins,lid switch is ok.something caught in water pump (very common),or a bad motor,(no spin or agitation),accompanied by burning smell usually..pls note:if something in pump,this can also prevent motor movement and cause overheating too
Mar 09, 2010 | Kenmore Washing Machines
Top loading kenmore washing machine frozen water loaded
Could it be that it has overheated? My mom's washing machine isn't a kenmore, but it has a mechanism that causes it to stall when it is overheated from constant use. After about 15 minutes it cools off and starts again.
Aug 07, 2009 | Kenmore 24032\24036 Top Load Washer
Makes a lot of noise when in spin mode
Hi...
If your machine makes noise you need to check this
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
Regards
PCmania
Jul 11, 2009 | Frigidaire Washing Machines
Loud noise in wash cycle
hi,
i recoomend you to perform the following checks,
  1. Inspect the filter screens
  2. Test for overheating
  3. Inspect the water pump
  4. Test the water inlet valve
  5. Test the motor
Thank you.
Jun 06, 2009 | Maytag HAV2460AW Top Load Washer
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
