I have a Mitsubishi lt-46265 and one by one all of the video inputs have quit working. Hdmi first them component. Anyone else have this problem? I believe the main board 934c39601 is bad but don't want to buy the wrong board. Iam a young TV tech but this one is a first for me.
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 16, 2014
SOURCE: blue screen with HDMI
Check the power supply modular cable connection that is by itself in the upper right corner.  On the one my son-in-law has the double yellow jumper wire that connects to this plug in two locations was loose (not properly inserted) in the modular connector and had worked it way out.
Posted on Oct 26, 2007
SOURCE: PLTV-3750 37 inch LCD TV no longer sees signals from any AV inputs
crisp audio and video signals.
Posted on Jan 26, 2008
SOURCE: Maxent MX50X3 HDMI input
I had the same problem and found that the ground wire outside where the cable companys box is was not even hooked up. It was just hanging there, once I hooked it up it went away. The cable company gave me the run around telling me it wasn't their fault. I now have Direct Tv.
Posted on Jun 17, 2008
  • 231 Answers
SOURCE: PDP4210EA1 Plasma TV black and white pic on reg RF input-no signal on other inputs
does the DVD player connect to the same port as the regular cable vision ?
If no I would be looking at the port that the cable vision connects to, to see if part of that circuit is shot.
Another question, has the T.V. been moved from one location to another just prior to this happenning? As plasma T.V.s can only be tilted on a 15 degree angle.
Posted on Oct 16, 2008
  • 159 Answers
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Posted on Apr 24, 2009
Mitsubishi LT-46249 picture is completly green. How do i correct this?
First check all input cables, make sure all cables are good & plugged in fully. then check with a DVD player to all HDMI & component inputs. if none of this solves issue you may need MAIN PCB.
PT# 934C335007 $139.99
http://www.tvpartsguy.com/servlet/Categories
May 09, 2014 | Mitsubishi 934C3360 Power Supply Board -...
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
Component Audio Not working
Hello, where is the issue, audio or video? Your question has mixed messages. Thank you, Onkyo USA
Jun 02, 2017 | Onkyo TX-SR505 Receiver
How can I hook up 2005 Mitsubishi LT-3780D with cable TV? Because in the back of TV looks more like computer's monitor, I can not connect it with a cable cord.,
Your LT-3780 LCD is only one part of a two-part television system. The LCD is the "monitor" and the HD-4001 "Media Center" is where the inputs and outputs are for the television. The HD-4001 was included with the LT-3780. They are connected together with an HDMI cable and a Serial Cable for communications. If you don't have the HD-4001, you can connect your cable box or DVD player directly to the LT-3780 with an HDMI cable. You will not have any means to connect more than one device at a time, as this feature was performed by the media center. You will also be unable to connect any S-Video, Composite, or Component devices, as these connections are only on the back of the Media Center.
Aug 13, 2009 | Mitsubishi LT-3780 37 in. LCD Television
Single HDMI Input. Need to connect several HDMI components
Number 1 would be to connect the 3 Devices to a Receiver with 3 HDMI Inputs, So this way you get the HDMI Audio as well. 3 in and 1 out to the TV as you know. The other way would be to get a Key Digital HDMI 3 to 1 Switcher. I have used these a lot in the field on installs and they work Great. They also have 4 to 1 if you think you might need more. No programming of the piece you just plug in and setup your TV in the HDMI Menu and your other Devices. If they don't sync AUTO! The Receiver would be Best I feel, Some let you assign 2 different Video and Audio sources at once. Such as Video from a Game and Audio from a CD. Hope this helps out!
Apr 20, 2009 | Mitsubishi WD-73833 73" HDTV
Hdmi not working
Please rephrase you get an "ant screen"?
Does the sound work? What is your hdmi video output device?
At any rate, you can also try this quick fix. In the setup menu go to Source Select. Make sure these settngs are right:
Assign>HDMI = HDMI 1 - 4 (depending on device)
Input Mode>Input Mode = Auto
Decod Mode>Decode Moe = Auto
Other>Video Convert = On
Set this for sources (devices) you have connected to the hdmi.
Jan 03, 2009 | Denon AVR-4308CI Receiver
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
