Question about Craftsman Garden
How do you fill the hydraulic fluid for the craftsman kohler magnum 19.5 lawn trctor
Need to know how to fill the hydraulic fluid. i replaced a broken line now need to fill the fluid
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Craftsman Master
  • 1,917 Answers
Its hydrostatic fluid not hydalic fuid dont put hydralic fluid in it the fill is on the back of tractor on the transmission there is a dip stick do not overfill or you will blow seals
Posted on Dec 15, 2014
How to adjustvalves on kohler22 on craftsman
Gary, they may be hydraulic and not require adjustment, check the attached links, they will help determine and show how to.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://outdoorpowerinfo.com/engine_specs/kohler_valve_clearances.asp
How to Adjust the Valves or Valve Lash on Kohler Courage XT Lawn Mower...
Work on the Cub Cadet i1046 Kohler twin setting the valves
Owners Service Manuals
Apr 14, 2016 | Cars & Trucks
How to add hydraulic oil to Kohler pro 20
Use a tiny funnel and a rubber hose to reach the fill point easily
Jun 03, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
Craftsman rideing lawn mower will not go in reverse
check the linkage might be out of adjustment also for the blades check the safety switches
Apr 23, 2012 | Craftsman Garden
Need to know where to find fill plug and drain for john deere lawn trctor lx172.
you can go to home dopot or look in the phone book for a parts place
Aug 17, 2011 | Garden
I have a craftsman gt 6000 with kohler 18 hp magnum today it started fine and ran goodd for over an hour i put gas in it and ti would not stay runing it stated surging and popping and cuts off
Your carb is full of trash. you also probaly need to clean out the bottom of your fuel tank, blow out your lines and replace the fuel filter. I have 2 mowers with kohler engines and clean out the fuel tanks fuel lines and carbs 1 time a year. There is also a fuel shut solenoid on the carb this is normally problem if the engine does not run. but I am certain your problem is a simple fix, all you have to do is clean everything out in the fuel system.
Sep 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 42 inch craftmas mower and the fluid is leaking from the hydrastatic area, can I replace it with transmission fluid.
If you transaxle is leaking badly adding oil may not help long term,if you remove the back hitch plate there is a allen wrench plug or a rubber vent hose, you can add oil there,measure down from the top of transaxle and fill to within 1.5 inch of the top,always allow 1.5 in of air space in top to allow for expansion. Add amsoil or mobil 1 synthetic motor oil 15w-50 or 20w-50. Do not use transmission fluid or hydraulic oil.
Jul 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Find whe the oil filter is located
verry carefully. seriously, though, on a briggs engine, it will be on the left side of the engine at the bottom rear - on a kohler it could be in the same position or the left side top rear - on a kawasaki it could be either - get an oil filter wrench and unscrew the filter counterclockwise [if the filter is horizontal, slip some rags under it, there will be a mess], make sure the rubber seal on the old filter does not stick to the engine, if it does, peel it off, put a light coat of oil on the rubber seal of the new filter and screw it on clockwise, tighten about 3/4 turn after contact with the base
May 21, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
178 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
