I just bought a second hand 2012 DEFY Automaid 600. The first 2 cycles, the mashine actually damaged my kitchen cupboard during its spinning process. To avoid further vibrations, I tried to balance it out by leveling the wheels at the bottom. Since then, when I select a program and start it, it doesn't start the process of washing. It makes the sound of drawing water for a sec and and then stops. It does not continue. What could be causing the problem?
Lumpy816
  • 246 Answers
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
  • 291 Answers
SOURCE: defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
thanks and plse do not forget to accept the solution.
Posted on Apr 03, 2009
  • 6 Answers
SOURCE: Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Posted on May 08, 2009
SOURCE: defy automaid won't spin
Put the machine on its side and check the wires to the pump. i found one of the wires broke off the lug on the pump side. Could be from all the vibration from the drum. The machine will only spin if the drainage is working.
Good luck.
Posted on May 11, 2009
caroldon
  • 17129 Answers
SOURCE: Defy Automaid Washing Machine Model
Possible fault of the program controller unit, the program output to the motor when the cycle is in the SPIN mode must be checked.
Make sure that the output is available, check using a multimeter to confirm. If absent then check the program module to confirm.
Posted on Jun 13, 2011
Why would my Defy 600 Automaid drum stop spinning?
The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
See manual for your unit at this site.
Pre
Sep 05, 2014 | Washing Machines
My DEFY Automaid 600 does not heat the water
It is possible that the thermostat may be causing a problem if it is faulty. It might be sending wrong signal to controller confusing it to think water temperature is already reached and shut off the heater.
The thermostat may look like this part.
http://www.macspares.co.za/laundry/thermostat-defy-automaid-std-models?cPath=1_195_175&
Apr 25, 2014 | Washing Machines
PLEASE COULD I HAVE THE DEFY AUTOMAID WAHING MACHINE MANUAL FOR DAW285 MODEL
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number
Good luck,
John C
Feb 16, 2011 | Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Defy automaid instruction manual how to use
Apr 03, 2009 | Washing Machines
Defy automaid won't spin
Good luck.
Mar 10, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
