Question about Craftsman 3/4 Hp Garage Door Opener System Belt Drive Motorhead Only
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
Changed the batteries on all 3 remote controls and reprogrammed, still not work both ways ( open and close) Still can close the door but why not open when I need to get back in my home?
  • 504 Answers
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Posted on Dec 15, 2014
Why wont my 3 remotes (hand held & factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain drive
It could be that your door is binding on the way up and so it stops automatically. Try releasing the emergency pull cord and move the door up and down by hand to see if it is binding, probably near the bottom. The track may be misaligned or there could be something rubbing against the door.
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
How to fix my garage door opener?
I'm assuming you mean that it won't close, only open? If that's the case then your eye beams may need to be adjusted. The wall button can override the sensors whereas the remotes can not.
The remote mounted on the wall works fine but the hand held remote don't work.
are the batteries in the hand held new. Are you stand within 20ft of door opener. You may have to re-sycn the codes with the handheld.
refer to owners manual.
Oct 12, 2014 | Building Materials
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have a problem with the hand held remotes working on my garage door working
Look at the opener to see if you can see the small wire dangling form it. That is the antenna. Stretch it out and point it down for maximum range.
Aug 18, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Factory garage door opener
If this is the 3 button HomeLink Transmitter usually centered overhead above the rear-view mirror, this should work:
While the engine is turned off follow these steps to program up to three channels:
1. Decide which one of the 3 channels (one of the 3 HomeLink buttons) you want to program.
2. Press & hold the desired button through step 3.
3. When the HomeLink indicator light begins to blink slowly(this may take up to 30 seconds), hold your hand-held garage door remote about 1 to 3 inches away from the buttons & then press and hold the button on your garage door remote. Continue to hold both buttons until the indicator light on the HomeLink begins to flash rapidly(this may take up to 90 seconds).
If it still doesn't work, make sure the batteries in your garage remote are not weak, and try again moving the remote back & forth and left & right or turning it upside down while programming.
Also note HomeLink will not work with older garage door openers, especially not with ones manufactured before April 1st 1982.
Feb 18, 2010 | 2005 Buick Rendezvous
Liftmaster garage door openers Model # 3245 (remote Issue)
it is possible that when you programmed the car remotes you erased the pairing between your hand held remotes and the unit. Follow the instructions to pair the remotes again and you should be good to go.
Sep 16, 2009 | liftmaster Chamberlain Garage Door Opener...
I have lost manufacturers manual on my BMW 325ci 2001 model. i only require pages relating to the programing of automatic garage door thank you
NOTE: Some vehicles may require the ignition to be turned on or to the second (or"accessory") position for programming and/or operation of HomeLink. It is also recommended that a new battery be replaced in the hand held transmitter of the device being programmed to HomeLink for quicker training and accurate transmission of the radio frequency. Please use a ladder and do not stand on your vehicle during the programming steps for a rolling code opener.
Rolling Code Programming:
1. Press and hold the two outer HomeLink buttons until the indicator light begins to flash (after 20 seconds). Do not hold for longer than 30 seconds. Do not repeat this step to program additional HomeLink buttons.
2. Place the hand-held remote 1-3 inches from the HomeLink button you want to program.
3. Simultaneously, press and hold both the HomeLink and hand-held remote buttons. Do not release either button until step 4 has been completed. (If you reside in Canada, refer to the "NOTE" below.)
4. When the indicator light changes from a slow blink to a rapid flash, release both buttons.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the"learn" or "smart" button (usually near where the hanging antenna wire is attached).
6. Press and release this "learn" or "smart" button. (The name of these buttons vary by manufacturer.) There are 30 seconds in which to initiate step 7.
7. Firmly press, hold for two seconds, and release the programmed HomeLink button. Do this procedure again and, depending on the make of your garage door opener, do this procedure a third time to complete the procedure.
The garage should now activate when the programmed HomeLink button is firmly pressed and released. If not, give us a call or refer to the "Troubleshooting Tips" noted below. NOTE: If you reside in Canada, replace step three with the following: Press and hold the desired HomeLink button and "cycle" the hand-held remote. To cycle: Press and release the hand-held remote button every two seconds until the indicator light changes from a slow blink to a rapid flash(step four).
Troubleshooting Tips:
** Check the frequency of the garage door opener's hand-held remote (usually found on the back). HomeLink is compatible with radio-frequency devices operating between 288-399 Mhz.
** Put a brand new, store bought battery in the hand held remote. During the programming process (step three above) the battery's energy tends to drain (more so with an older battery). A new battery will increase the speed and accuracy in which the hand-held remote sends its signal to HomeLink.
** Retrain HomeLink holding the hand-held remote at different lengths and angles from the HomeLink button you are trying to program (during programming step three). Try 4-6 inches away at a different angle.
** Confirm that the HomeLink button you are trying to program is in the "programming mode". Press and hold the desired button. The indicator light will be a slow blink when HomeLink is in the "programming" mode and can be programmed at any time.
Verifying HomeLink has picked up a rolling code signal:
** Press and hold the programmed HomeLink button. If the indicator light blinks rapidly for two seconds and turns solid, HomeLink has successfully picked up the rolling code signal. If necessary, proceed with steps 5-7 noted above to complete the rolling code programming.
Sep 09, 2009 | 2001 BMW 325
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 3/4 Hp Garage Door Opener System Belt Drive Motorhead Only Logo
208 people viewed this question
Top Craftsman Building Materials Experts
richie46
ray gallant
rdjagger
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
