Question about Sewing Machines
Hi. I need instructions for threading a Pegasus dcr603 overlocker...can you help?
Have tried several ways but to no avail
  • Sewing Machines Master
  • 1,860 Answers
Try this link and see if they can help you
Pegasus Sewing Products
Posted on Dec 15, 2014
Manual for singer merrittlock 14u44
Most Singer manuals are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 14U44 is http://www.singerco.com/uploads/download/1292_14u44b,244b.pdf . The manual covers several Singer 3/4 thread overlock machines.
I hope this helps.
Oct 25, 2017 | Singer Sewing Machines
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
Hi, my overlocker isn't stitching corrrectly, I have cleaned, oiled and re threaded, do you think a new needle would help?
Have you tried setting thread tension?
Maybe that's problem
The thread tension should be equal from bobbin or from spool of thread.
Hope this helps.
Mar 17, 2015 | Sewing Machines
I need instuctions to thread a Pegasus overlocker sewing machine.. have threaded several ways but the machine still does not overlock..the threads do not pick up properly to form the looping
I need to know the model number of the Pegasus to see if I can find some instructions on threading. so if you will send me a comment with the model number I will check for you.
Dec 15, 2014 | Sewing Machines
My pegasus industrial 5 spool overlocker type L52-18S1 spec 2x4 dose not overlock in the threads
the machine may need to be taken in to be checked to see if it's
out of time
Jun 07, 2012 | Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
Hi. About 5 years ago I purchased a Janome 744D Overlocker which I have only used once because the thread on the underside keeps snapping, and the needles keep breaking off. The foot is also very touchy...
Yes, overlockers sew fast, usually 1500 stitches per minute and with a blade in action alongside the loopers so there is a lot happening. Keep all pins well away from the seam edge, contrary to normal sewing machine techniques, if you pin two layers together, then place the pins parallel to the fabric cut edge at least 2 inches away from the edge so the pin goes nowhere near the foot or blade.
Check whenever you use it, that you firstly extend the thread aerial up to full height, you need to ensure the threads can flow smoothly to the tension dials as the thread will stream off fast, even the slightest catch of a thread will snap one, throw your tension out or damage a looper.
As you've had it all this time and not used it, why not consider investing a few dollars more and go to a class on overlockers, and learn how to thread it up for three, four, rolled hem and using the differential feed. If there is no class options in your area, then try the Janome dealer near you and see if they would consider giving you a a little lesson on using it. You could also check out the videos on You-tube or read some pages from Debbie on www.sewing.about.com, she has several pages on sergers (USA name for overlockers), explains the needles, threading, different techniques and maintenance. Or check out your local library for any books on sergers/overlockers, there are several good "how to" guides out there that would certainly help you get started.
Unfortunately there is no way to slow the speed to half speed, just practice with lots of fabric scraps at first, to get used to the sensitivity of the foot control. If you do dressmaking but aren't sure where to overlock or which seams you could only overlock, then consider just doing a three thread overlock around the edge of each fabric piece before you commence assembling the garment, just do your notch markings another way such as chalking them or using water soluable marker pen as the blade will cut away your outwards notches.
My other suggestion would be to make a simple sweat shirt on it using the 4 thread stitch and not touching your sewing machine at all. Once you've made one, you'll soon be wizzing them up in 30 mins, so quick to sew knits on an overlocker. Some of the commercial patterns are marked as suitable for sergers, look for one of these to try.
I hope this helps you to master your overlocker, a lesson or class would help you with the steep learning curve at first.
May 22, 2011 | Janome Sewing Machines
Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
Jul 18, 2009 | Sewing Machines
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
