Question about Sylvania Computers & Internet
I want to restore my sylvania netbook syn6160 to factory using usb I guess
Everything I found on the internet F3, F8 F11 downloading usb restores that didn't work
Windows xp doesnt work booting from usb. have to use a cd. if the computer does not have a cd/dvd device, use a portable. if you want to format to windows 7 and your usb device does not appear on boot menu.go to bios settings advanced settings and look for usb device and enable. if the computer supports booting from usb. Im sorry i cant provide you with more, but i couldnt find your model on the internet so i really dont know what im looking at. best regards.
Posted on Feb 05, 2015
SOURCE:
  • 37 Answers
SOURCE: dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Posted on Jan 06, 2009
pumpkinman
  • 1176 Answers
SOURCE: I can't restore my Dell Ins 6000/centrino to factory
no only with disk you have lost the restore part of factory restore
Posted on Oct 17, 2009
  • 162 Answers
SOURCE: how can i restore my inspiron 1521
if your running Windows Vista you can try this http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R143625&SystemID=INS_PNT_PM_1521&servicetag=&os=WLH&osl=en&deviceid=3601&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=7&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=191736
That's an Image File that re-installs windows onto your machine, just make sure you read the instructions if.when you use it :-).
Posted on Jul 09, 2010
  • 1273 Answers
SOURCE: i could not get my sylvania netbook to connect to
I do not know why your icons disappeared by running the Download, but your programs are still in the on board ROM memory and what you are missing are your desk top icons. I have tried to duplicate your download problem but so far have not been able. I know that using a SD card will not download a usuable file so I used a thumb drive.
Any way please read the following solution that I wrote to another poster.
If you have deleted the icons for those programs on your desk top, then they may be in your Recycle trash bin. double click on Recycle Bin look for the icon for recorder, right click on recorder and select restore. You really cannot delete the programs from your machine as they are retained in a ROM chip , hard coded into the chip and are loaded each time you cut your machine on. The only thing you can do is delete the icons on the desktop, which are sent to the recycle bin.
To retore the machine to factory settings, there is a small hole just about an inch down from the data plate on the back. Using a pencil point or a straightened paper clip, insert the bject into the hole and hold for about 5 seconds. Your deleted icons are not replaced.
A second method to restore your icon is to click on my computer right click on the recorder, select copy, dismiss my computer, find a blank spot on your desktop and right click on that spot, select paste, and a dos type icon appears as your recorder button. When you cut the machine of and back on the Dos type icon is replaced with a CE type icon
To restore all icons:
You can: If you can click on start, click on run, type desk top into the open space and ok it. your icons should be shown. you will have to copy and paste each one back to your desk top, or select edit and then select select all, then click on file, select send to, and select desk top as short cut. Reply
Posted on Dec 12, 2010
crok41
  • 621 Answers
SOURCE: Acer Aspire One Netbook picked up virus, internet
You will need to boot from a windows CD / DVD if you dont have one borrow one do a full format and reinstall. When you do get it all back to new do yourself a favour and put an anti-virus program on it there is planty of free ones out there which work great. AVG or Avast are a few good ones.......good luck with it and please vote
Posted on Jan 26, 2011
Medion e1210 factory setting
Usually, if the recovery partition is still intact, pressing F8 just before it boots and selecting restore does the job. All data will be erased permanently!
Jan 24, 2015 | Medion Computers & Internet
Sylvania Netbook SYNET7WID frozen on OS Image what do I do?
When you turn it on, as soon as the very first screen appears press F11.
Than it should take you straight to factory restore settings. P.S.
This will delete everything it so safe your stuff in Hard drives or flash drives.
hope this helps
Oct 06, 2012 | Sylvania G-Netbook
Im locled out of my sylvania netbook
When you turn it on, as soon as the very first screen appears press F11. Than it should take you straight to factory restore settings. P.S. This will delet everything it so safe your stuff in Hard drives or flash drives.
Feb 11, 2012 | Computers & Internet
How can I return to the original system software that was in my Sylvania Netbook? Thank you. Jerry Kleker
Hi and welcome to Fixya!
To return to the original settings of the netbook, just follow this step;
When you turn the machine on, as soon as the very first screen appears press F11. It should take you straight to factory restore settings.
Restoring the machine back to factory settings will erase all changes (including personal files) on the machine so its better that you backup your files all the time.
Hope this helps!
Takasashi
Jul 23, 2011 | Sylvania G-Netbook
Copy not genuine.. i want a factory restore..
When the computer is turning on, if it is windows 7 press f8 and select Repair. You will see the factory reset. Otherwise press f11 (or ctrl + f11), it will take a couple of tries.
Jul 03, 2011 | Dell Inspiron Mini 1012 Netbook...
ASUS Eee PC 1005HA-PU1X-BK Netbook how do fix black screen issue?It has an upper left corner blinking dash_
Hello.
Either you have an operating system problem or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Jun 25, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How do I reset my slivania netbook?
When you turn it on, press F11. Then it should take you to factory restore settings.
Just be aware that all the files you created will be delete. So make sure you saved your important files somewhere else before proceeding.
Thanks for using Fixya!
Jun 09, 2011 | Sylvania G-Netbook
My windows netbook boots but immediately goes to a black screen with a blinking cursor. It will allow me to press F2 at boot to go into a setup menu but will not boot into windows. How can I fix this?
Hello.
Either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this resolves your problem.
Nov 30, 2010 | Gateway LT2001u Netbook
Tough infection keeps returning
Hello.
If the malware is reinfecting your system, you really only have 3 choices: System Restore, Factory Restore or reinstall.
For System Restore, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this helps.
Dec 04, 2009 | Microsoft Computers & Internet
How to restore netbook back to manufacturer setting?
Turn off computer.
As soon as you turn it on keep tapping Ctrl+F11 or F11.
Then you will be taken to a complete PC restore screen. Then you can follow the instructions to resore your PC to factory defaults.
If you are using Vista.
Then press F8 and then choose the option Repair your computer. In that you will have an option to restore to factory defaults.
Sep 10, 2009 | ASUS Eee Pc 904Ha Notebook
Computers & Internet Logo
70 people viewed this question
Top Sylvania Computers & Internet Experts
Norman Worley
Joe Negus
Joe Negus
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
