Question about Kenmore HE2 Plus Front Load Washer
Water Drains from underneath the soap dispenser when I start machine.
    New Friend:
  • 4 Answers
This could be an easy fix. Lift out the whole tray and wash in really warm water in your sink and wipe out anything you see inside the machine. It could be a lump of Downey or soap caught up. Good Luck.
Posted on Dec 15, 2014
How to clear a blockage in the drainage tube from the soap dispenser to the tub?
best to take the top off by removing the bolts in the back the slide it to the back then off.you then can get to the hose and remove it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 04, 2014 | Samsung Washing Machines
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Aug 22, 2010 | LG Washing Machines
I have the CFW-8000 washing machine. When the
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Nov 18, 2009 | Crosley Washing Machines
We have a Kenmore frontloader pooring water from soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 16, 2009 | Kenmore 44102 Front Load Washer
My washer is leaking water from underneath. How can I fix this problem
Are you sure its from underneath as a lot of washers seem to be leaking underneath but its actually a blockage in the soap dispenser. Or the water pressure is too high and splashing out of the dispenser in this case make sure the m/c is level front to back.
Mar 07, 2009 | Roper RAS8244KQ Top Load Washer
Fabric softner dispenser
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
Oct 30, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
