Question about Sony Bravia 36 40 42 46 50 52 55 LCD Compatible Articulating TV Wall Mount Bracket With Free 10FT Male To Male HDMI Cable Adjustable Tilting Swiveling Wall Mount Bracket for LCD LED Plasma 3255 Inch Flat Screen Panels
Kdl 40ex400 logo come own then color bars
Nothing yet I think it's the viedo br.
    Top Expert:
  • Sony Master
  • 74,243 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 15, 2014
Sony Bravia KDL-40EX400: great pic in black/white, but no color. Few years old; unused for about a year, and set up recently; worked great before it was stored. Did a factory reset/checked cables.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 28, 2016 | Sony BRAVIA KDL-40EX400 40" LCD TV
Will the power supply cord for sony bravia KDL 40ex500 work on 40ex400?
Usually manufacturers use as many standardized components as possible to reduce costs so it is highly probable that the power cord on both a 40 & 50 inch sony tv in the same series is identical.
Jun 27, 2015 | Sony Televison & Video
Model # KDL-40EX400 sony bravia screen black on power saving picture off mode how can i get my tv to function
Unplus tv and plug back in 10 seconds later. Go into menu and turn off eco setting. Check timer setting and turn it off also. Your complaint is unclear . I hope this helps.
Mar 18, 2014 | Televison & Video
My Sony BRAVIA KDL-40EX400 will not turn on.
IIC bus clock and/or data lines low at power on 06. This is the fault, according to the blinking codes given by Sony LCD TVs. That is, the fault lies within the main digital board. To locate the exact fault point to these type of fault, is actually a skilled one. If you wish to get more details to this fault, check the link sited here.http://electronicshelponline.blogspot.com/ It has details about these blinking codes. Before proceed, once again count and make confirm the number of blinks occur at one time switch ON. Pull up older posts by this link at its left side bar.
Jun 06, 2013 | Sony BRAVIA KDL-40EX400 40" LCD TV
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
I would like to know if the t-con board out of a SONY KDL-40EX500 will work in my KDL-40EX400 they look the same
that"s difficult things. but you could try it. but you must check its --t-con board all connection if it same include which connection to what & all voltage must be same. good luck!
Sep 03, 2012 | Sony BRAVIA KDL-40EX400 40" LCD TV
I need to program my Sony kdl-40ex400 with Sony rm-vz320 remote
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Setup codes for Sony TV can be noted from this site. Pull out older posts there. There are more than 220 posts there. All are about electronics service help.
May 20, 2012 | Sony Televison & Video
NEED SERVICES MANUALS FOR SONY KDL-40EX400
Have you tried to GOOGLE the model number with service manual after it?
I will presume you have checked the fuse on the power cord inside the set.
The more you tell me the better I can assist you.
Mar 14, 2012 | Televison & Video
Sony Bravia 36 40 42 46 50 52 55 LCD Compatible Articulating TV Wall Mount Bracket With Free 10FT Male To Male HDMI Cable Adjustable Tilting Swiveling Wall Mount Bracket for LCD LED Plasma 3255 Inch Flat Screen Panels Logo
90 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
