Question about Coffee Makers & Espresso Machines
How do I set time for tea - Coffee Makers & Espresso Machines
  • 705 Answers
Please add some more detail about the make and model of the equipment your question relates to. This will get you a more accurate answer.
Posted on Dec 16, 2014
SOURCE:
How often can I reuse a tea bag?
When you use a tea bag , you get 80% of good tea in first use and in the second use out of 20% you get only 16%. Except this is the case where value gets uselessly skinny very quickly .So reuse your tea bag one or two time , after that it is spent.
Aug 12, 2015 | Wine & Spirits
How do you use loose tea to make tea in a pot?
You can use steel pot to make a Tea, do you know Loose tea is very simple to make.
If you will use steel pot that is easy to hold and keep.
Feb 27, 2013 | Home
Where can I buy a glass tea pot and matching cups?
Glass teapots have become quite popular recently. Here is a link to the English Tea Store, where they sell a glass pot and matching cups.
http://www.yorkshiretea.co.uk/about-tea/yorkshire-tea-how-to-make-a-proper-brew.php
Feb 27, 2013 | Home
How do you make a proper cup of English tea using a teapot?
There's more to making the tea than just shoving a few bags in a tea pot and adding hot water. Lovers of English tea believe that you need to warm the pot beforehand and let the tea brew before you start. Take a look at this article on the Yorkshire Tea website that gives a good run down of how to make tea.
Feb 27, 2013 | Home
Where can I find a timer specifically for tea?
this one times from 1-20 minutes an even lefts out the tea bag after that!http://www.amazon.com/Penguin-Tea-Timer-31-1000-00-00-Tea-Boy/dp/B00008WV6K%3FSubscriptionId%3D19BAZMZQFZJ6G2QYGCG2%26tag%3Dsquidooa2224-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB00008WV6K
Jan 14, 2013 | Home
Own the 3 qt ice tea maker. When making tea it leaks around the seam in the front of the machine and pours out all over the counter and not into the tea maker; any fixes or suggestions to remedy this messy...
I have this same problem. There seems to be two sources of the leak, described below. However, I think Mr. Coffee should re-design the offending parts.
1) bad fit between the brewer and the pitcher, caused by a pitcher that stands too high, preventing the pitcher's spout from snuggling into the brewer. I avoid this problem by brewing without the lid on the pitcher.
2) the brewed tea does not flow straight down from the brewer basket, especially when the tab is set to "strong". In this setting, the brewed tea is forced through a tube, in order to spend more time steeping. However, if you watch the tea flow out and down, you will see it bend to the left and thus miss the catch spout of the pitcher (and flow onto the surface, leaving the impression that one of the parts is "leaking") . I think this is caused by buildup of particulate matter from the tea and/or hard water deposits. My solutions here: try the tab in the "mild" setting; and/or clean the basket drain holes occasionally, especially if you have hard water (soak in vinegar to remove hard water build-up). You may need a tiny bristle brush to clean the small holes in the basket. Also, try to fit the pitcher into the brewer as far to the left as possible.
Hope this helps.
Gary in Torrance
Mar 02, 2011 | Mr. Coffee Iced Tea Maker TM1S
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
